January 06, 2025, 03:34:08 AM
woodcraft clip-on's
Topic: woodcraft clip-on's (Read 6893 times)
Ranger06
woodcraft clip-on's
September 11, 2008, 07:24:12 PM »
I just ordered a set of Woodraft clip-on's for my 08 695 and hope to put them on this weekend. Any advice on installing them or is it pretty straight forward? I plan on keeping the stock upper triple for now, but it will be the next to go. Any recommendations on weather or not I should drill them for the controls?
Thanks
2008 695 Dark
c_rex
Quick! Into the transmogrifier!
Re: woodcraft clip-on's
September 11, 2008, 08:17:19 PM »
well I just drilled my new LSL clip on bar for controls yesterday and it took me about 5 minutes to get out the drill/bits, fetch my wife's nail polish, dab polish on lock post, temp mount control to bar for polish print location, drill successive holes to proper size (11/32 I think it was- can check), then final fit controls to the bar. honestly- five minutes, probably less. it's easy as...
/shrug
OwnyTony
September 12, 2008, 04:56:04 AM »
Quote from: Ranger06 on September 11, 2008, 07:24:12 PM
Thanks
All i know is that I am having problems with my install with woodcraft. There is no rise to them.
Ranger06
September 12, 2008, 05:20:35 AM »
I picked the woodcraft because there was no rise to them. Why is this causing an install problem for you? are there clearance issues?
2008 695 Dark
El Matador
Do I need knee pucks for my
September 12, 2008, 07:13:26 AM »
The problem that you might encounter is that if you dont lower the headlight, your reservoirs might not fit. Which means you might have to flip the clip ons if you don't want to lower the headlight, which in turn looks kinda funky.
Also, it's important to note that without the lowered headlight the bike will look weird.
Finally, the mod is totally worthwhile and is one of the best handling mods I have done to the bike, It looks killer and the handling is completely transformed.
pics to illustrate:
Flipped clip ons, no lowered headlight or gauges
Lowered headlight and gauges, flipped clip ons
El Matador
September 12, 2008, 07:16:12 AM »
And finally, lowered gauges and headlight, clip ons on like they're supposed to be:
El Matador
September 12, 2008, 07:17:07 AM »
Pm me if you have any questions about any stage of the process
Good luck on your mods!
Ranger06
September 12, 2008, 07:24:54 AM »
Good stuff, looks like I will be lowering the headlight too. I've been checking out how some of you lowered yours in the "How To" section. Seems like it only needs to come down an inch or so. I'll post some pics once I get it done. Thanks for the advice
2008 695 Dark
El Matador
September 12, 2008, 07:27:09 AM »
Quote from: Ranger06 on September 12, 2008, 07:24:54 AM
Awesome. The easiest way to do it is this one:
http://ducatimonsterforum.org/index.php?topic=1050.msg42151#msg42151
ICON
September 12, 2008, 07:40:36 AM »
Quote from: c_rex on September 11, 2008, 08:17:19 PM
/shrug
Perfect explanation, but if you don't have a Wife or Lady friend around, use whiteout.
Murdered Monster
September 12, 2008, 09:51:17 AM »
Very nice!
'09 M696 Dark
OwnyTony
September 12, 2008, 10:46:01 AM »
The problems I am running into are that the MC's do not have enough room. I dont have coffin ones, I upgraded to the remote reservoir/cup masters.
Also, you will notice that matador does not have his stock turn signals on (a plus in my book. Also, im wondering what he used) so plan to have a replacement on hand.
I ended up buying a cyclecat triple clamp off of ebay. Comes with triple, slight rise clipons and the top of fork extensions so i can mount clipons on top of fork.
Even with my lowered headlight, there is a slight clearance issue. Brake lines and such and masters hitting the top of the stock triple. I plan on using my front bikini fairing so I may have extra problems to deal with.
ghostface
September 12, 2008, 11:03:49 AM »
Installed them on my S4 and had clearance issues with the stock signals.
c_rex
September 12, 2008, 11:09:00 AM »
You are still using the stock MC brackets yeah? You can make your own out of stuff from the hardware store and/or mount them from another place that allows you to fit the MCs. I've got mine mounted from the headlight bracket 'ears' on bent Rizoma brackets. This is a pre-clip on picture but it looks like this:
OwnyTony
Reply #14 on:
September 12, 2008, 11:40:06 AM »
Quote from: c_rex on September 12, 2008, 11:09:00 AM
Looks nice. May have to consider doing that myself. What kind of masters do you have?
