eltristo
Go Go Gadget
Humble servant of MBG
« on: September 13, 2008, 07:45:47 PM » |
So it seems at least two (2) of us have suspension that needs installin', and I have a tail to mess with. Is the MacHoist offer still open for fork fiddlin'? When might we want to get down-n-dirty?
"Health! The open sesame to the sucker's purse."
teddy037.2
« Reply #1 on: September 13, 2008, 10:22:20 PM » |
won't you need to fix the tail before you can ride it anywhere to swap your forks?
eltristo
Go Go Gadget
« Reply #2 on: September 14, 2008, 08:51:51 AM » |
yup haven't really put that one together yet
MadDuck
The anti-
« Reply #3 on: September 14, 2008, 09:02:26 AM » |
Mac Hoist offer is still open. As a matter of fact I have to tighten the steering neck bearings on the Monster. I've been meaning to do that for a year or so I guess. I will likely do that on a Saturday the week after next. Sept. 27th.
eltristo
Go Go Gadget
« Reply #4 on: September 14, 2008, 10:33:05 AM » |
I'll try to get that day off, or at least limit the time I spend at work.
eltristo
Go Go Gadget
« Reply #5 on: September 14, 2008, 05:12:40 PM » |
So I've been doing my tail, mounting the new parts, etc. All is kinda getting toward ready, but now a seemingly insurmountable problem: the turn signal bolts are too long and are hitting the frame. I'd cut them, but the wires run thru em, and there is no way I'll cut the metal and not the wires. I thought i'd drill thru the frame, but my drill is underpowered and my dremel doesn't have the diameter. Poo!
teddy037.2
« Reply #6 on: September 14, 2008, 08:04:45 PM » |
is everything sorted?
we can monkey around w/it tomorrow after work if you need to...
eltristo
Go Go Gadget
« Reply #7 on: September 14, 2008, 09:07:12 PM » |
Unsorted! And I'm probably working all day tomorrow. More poo!
MadDuck
The anti-
« Reply #8 on: September 14, 2008, 10:13:05 PM » |
Take the lights out/off and pull the wires through the post. Cut post to length and clean threads. Reinstall light & wires.
eltristo
Go Go Gadget
« Reply #9 on: September 15, 2008, 09:37:19 AM » |
I will try that
DesmoBlob
Yes
« Reply #10 on: September 15, 2008, 11:46:58 AM » |
Monkeying around is definitely better than going ape. Though both are decidedly simian.
eltristo
Go Go Gadget
« Reply #11 on: September 15, 2008, 11:17:21 PM » |
Well, no go on the blinkies. I couldn't so much as wrestle the bulb out, much less the rubber grommet bit or anything else. Double boo.
teddy037.2
« Reply #12 on: September 16, 2008, 01:45:15 PM » |
hmm. this willl require some thought...
« Reply #13 on: September 16, 2008, 01:48:03 PM » |
hmm. this willl require some drinks...
Fixed!
teddy037.2
« Reply #14 on: September 16, 2008, 02:05:38 PM » |
