January 06, 2025, 03:22:05 AM
New Rizoma Bling....
Topic: New Rizoma Bling.... (Read 4079 times)
lazarus7
September 16, 2008, 12:25:02 PM »
just finished 2 hours ago....
nice stuff....
rearsets are next...!!!
Last Edit: September 16, 2008, 12:31:31 PM by lazarus7
"...the greatest artists indulge in a 'culpable rivalry' with God." Stanislas Fumet
DucSteve
Hey Yo
Re: New Rizoma Bling....
September 16, 2008, 01:47:52 PM »
holy clean, do you even ride it?
Bbrent
'08 S4RS Tricolore
September 16, 2008, 02:08:09 PM »
I did something similar to what you did for the mounting but I used some big ugly bolts in the mirror holes. I like your setup much better what bolts did you use and where did you get them?
Brian
lazarus7
September 16, 2008, 02:56:35 PM »
those are 999 fairing bolts and flatwashers
bolting into a well nut pressed into the stock mirror thread/ socket/ recess...
not SOLID solid, but enough to suit my tastes....
S2daRk
September 16, 2008, 06:47:15 PM »
Lookin' good! I want to get some Rizoma bling too. Where do you recommend getting them from? Also, I noticed the front brake reservoir is larger than the clutch reservoir...is this the popular setup? Would it be ok to use the same size as the clutch?
lazarus7
September 16, 2008, 07:04:27 PM »
http://www.pjsparts.com/catalog/index.php?cPath=267_46
these guys are awesome....!:)
those are the recommended sizes,
i would think that the braking system would need a bigger reservoir since they have
those large brake pistons to move a greater distance....
i DID see someone use 2 matching ones, but have no idea
if its a better or worse setup...
this one is great.
Bbrent
'08 S4RS Tricolore
September 16, 2008, 07:21:04 PM »
I use the same tall reservoirs for the brake and cluth and thesmall one for the rear brake. No problems. I do check them every couple weeks or so, but I haven't had to add any fluid to either of them. Pj's parts is the place to shop for all your Rizoma stuff.
Dirteagle
The Monster rules the Toy Box
September 16, 2008, 07:31:50 PM »
WOW! Very nice and clean.
(Note to self; Clean bike better)
Great, now I have to add those to my list of things I need. Well, not that I need, what I want. A Lot!
Looks great Lazarus7. Thanks for the pics.
It`s not what you ride, it`s that you ride!
2008 Monster S4rs Tricolore
q monster
September 17, 2008, 05:52:14 AM »
nice lazarus
i've got a bit of rizoma on my s2r1k - the LED indicators are f hot and i've also added the grips. Titax levers are on the way as they're shorter and closer to the bar than rizoma's
q monster
2008 S2R1000 changed - spark headers and tail cut done, rizoma grips indicator lights and clutch cover titax levers, DP ECU, open filter, ...... maybe stop then............. nah think i'll add rizoma rearsets and their conical handlebar is f..hot... and then i need to get rid of those mirrors....
lazarus7
September 17, 2008, 05:59:42 AM »
yeah ive got a clear alternatives in the back, definitely going with rizomas
in the front, just havent decided which ones yet...
i run pazzo levers on all my bikes, crgs on the 696, like them both...
rizoma rearsets are definitely next on the list....
Heath
September 17, 2008, 04:20:50 PM »
No rizoma levers?! WEAK!!!
(at double the price I understand
nice bling
2007 Ducati Monster S4RT
geoffduc
18 till i die
September 18, 2008, 12:30:26 PM »
hi lazarus,
nice work with the mods.i have done very similar on my s4rs but instead of the flat bar brackets i have used rizoma billit brackets part no ct450b.they use the same screw hole as the original bracket on the levers so as to look like factory fitment plus they look really trick.just my 2cents
2015 scrambler FT
2009 monster 1100s
lazarus7
September 18, 2008, 12:53:58 PM »
thanks for the heads-up.....
those things are MASSIVE....
look like freakin' bridge girders....!!!!
cool, but i dig my little thin ones just fine, thanks....
