K&N pod filters and custom battery boxes
Started by Smokescreen, September 16, 2008, 01:49:08 PM
Smokescreen
I've seen K&N pod filters on Carbed Monsters but nobody seems to know what the part number for these are.  Can anybody help me with this?  I want to change to pods so that I can reroute electrics to the middle of the bike.  Not concerned about the water issue, it'll be replacing an open box.  Also, does anybody make a custom battery box with mounts for coils?  I'd rather not chop up the stock part, as I might want it again some day, and I lack a welder to make my own.
Catching a yellow-jacket in your shirt at seventy miles per hour can double your vocabulary.
Only a biker knows why a dog sticks his head out of a car window.
MaxPower
Nobody snuggles with Max Power. You strap yourself in and feel the Gs!
2003 M620i.e.
greenmonster
M900 -97
MTS 1100s  -07
Smokescreen
so for the record, that's RU-1750 k&n part number
as for the battery box, I like that, I may well try it after I've done this valve adjustment and throttle body sync.  When done, I'll post up a pic or two.
Smokescreen
also of note however, is that the filters listed are angled and designed for a setup where both carbs aren't aiming in the same direction at the top.  The monster's aim in the same direction.  But at least it landed me the needed data
flange inner diameter 62mm, outer base 95mm.  I just need to verify that this outter base will work if these are right next to each other.
