25mm rear axle torque value?
Started by Teutonics, September 17, 2008, 07:19:28 PM
Teutonics
I searched, and couldn't find it...
I have the factory s/m for my bike, but the manual is an '00 and my bike is an '02.  The torque value in the manual is for a 17mm rear axle, and mine is a 25mm axle.  The torque spec stated for the 17mm is 72 Nm, but is it different for the 25mm?
TIA!!!
Atlanta, GA - 2002 M900ie
Quote from: Teutonics on September 17, 2008, 07:19:28 PM
TIA!!!
I don't know the answer, but if the rear is hollow like the front...
I'd use the same value...
which is 63 Nm with greased threads
<howie voice>
No, it's hollow.
</howie voice>
Quote from: Speeddog on September 17, 2008, 07:40:58 PM
<howie voice>
No, it's hollow.
</howie voice>
<dp voice>
Weird that the same fastener on a similar shaft size takes a different torque.
</dp voice>   ;D
Teutonics
Awesome, thanks for the quick response!!!
Quote from: ducpainter on September 17, 2008, 08:00:08 PM
<dp voice>
</dp voice>   ;D
From the factory manual:
Front wheel nut M 25x1.25 63 * GREASE B
Rear wheel shaft nut M 25x1.25 83 * GREASE B
No idea why.
I haven't done a calculation recently, but IIRC, chain tension plus forward thrust at the rear axle can be ~1500 lbs at WOT in 1st gear, so that makes sense to me to have more pinch.
Quote from: Speeddog on September 19, 2008, 10:38:29 AM
Definitely makes sense.
