November 24, 2024, 08:27:07 PM
Please Help
OZ monsters
Oz Monster Trading Post
23
24
25
26
106
Topic: Oz Monster Trading Post (Read 522544 times)
CanMonster
Re: Oz Monster Trading Post
Reply #345 on:
July 10, 2009, 03:03:30 AM »
Just an update : I found all the bits I needed at
www.eurobrit.com.au
Hi All,
I have a 93 Monster that gets carby icing in Winter. This was fixed in the 95 models and onwards. There used to be carb. heating kits for them does anyone know if these are available in Australia?
Cheers,
Nathan
Last Edit: September 10, 2009, 11:55:44 PM by CanMonster
Cheers,
CanMonster
DUCMONROB
Geez its getting hot holding my
Nothing like the sound of a Ducati!
Reply #346 on:
July 10, 2009, 03:37:03 AM »
Quote from: CanMonster on July 10, 2009, 03:03:30 AM
Hi All,
Cheers,
Nathan
What you will need Nathan is two fuel bowls and the hose kit which you should be able to get from a wreckers somewhere like Metropolitan. The kit has a tap which can feed the hot oil through your carbs instead of going to the oil cooler.
Good luck
Rob
M1000SDS, ZZR1200, GPZ900R.
Gone:
900 Monster Special
S2R1000
998 Matrix
Dannog
S4RS
Reply #347 on:
July 12, 2009, 05:08:09 PM »
Quote from: Dannog on January 21, 2009, 09:45:22 PM
Is anyone interested in doing a SBK fork upgrade?
I have the following:
'05 Ducati 53mm Showa Forks Gold TiN SBK 999 forks that I was planning on installing on my M900, 65mm caliper spacing
Carbon Fibre S4RS front fender to suit 999 forks
5mm shims for rotors
Happy to consider sale as whole or in separate.
taking up too much room so make me an offer!
CanMonster
Reply #348 on:
July 15, 2009, 11:34:43 PM »
Hi All,
In luei of a carburetor heating kit for a '93 Monster I am after a set of carbies from a Monster 1995 to 1999. I believe there compatible with the '93 Monster. The Keihin flatsides are a bit pricey and apparently are problematic.
Cheers,
Nathan
Cheers,
CanMonster
CanMonster
Reply #349 on:
July 15, 2009, 11:36:20 PM »
Thanks for the tip Rob. I will check it out!
Cheers,
CanMonster
dragonworld.
I can make like a tripod with my.....
Reply #350 on:
July 16, 2009, 09:48:40 PM »
Quote from: CanMonster on July 15, 2009, 11:34:43 PM
Hi All,
Cheers,
Nathan
There are a number of Yamaha models that ran these carbs, early TDM's, FZ750 and FZR 1000's. Might give you some more options in the hunt.
DUCMONROB
Reply #351 on:
July 17, 2009, 01:12:56 AM »
Quote from: dragonworld on July 16, 2009, 09:48:40 PM
TRX850 too!
Gone:
900 Monster Special
S2R1000
998 Matrix
mattyvas
Reply #352 on:
July 23, 2009, 12:15:25 AM »
Got a line on some Termi's from Rob at Flywheels in Sydney.
They are from a customer of the shop. Apparently opened only to check all fittings are present.
Never been fitted, sorry I have no photos as they are not in mine.
So pipes are: Termi Carbon High Mounts - $1250
Contact Rob @ Flywheels 02-9699 7800
My new web home is now at
www.mattvas.com.au
MattyVas Flickr Photos
OzMonsters Flickr Photos
wayne800
Reply #353 on:
August 07, 2009, 11:31:38 PM »
Hey, I'm Sydney based and just wondering if any members have some stock right side (S2R 800) parts they want to sell off, namely:
- Mirror
- 'bar end
- Hand brake lever
- Clutch case cover (wet)
- Foot brake lever
- Pillion peg
- Rear indicator
This is sounding expensive so I'll probably end up going thru' insurance but thought it's worth asking you guys first.
Cheers
dragonworld.
Reply #354 on:
August 08, 2009, 12:15:05 AM »
OOOPS??
DUCMONROB
Reply #355 on:
August 08, 2009, 01:46:57 AM »
Quote from: wayne800 on August 07, 2009, 11:31:38 PM
- Mirror
- 'bar end
- Hand brake lever
- Foot brake lever
- Pillion peg
- Rear indicator
Cheers
Sounds like some thing I did recently.
Genuine front brake leaver $167, Indicator $42, foot peg $45, rear brake leaver $130.
Sorry for the bad news.
Rob
Gone:
900 Monster Special
S2R1000
998 Matrix
wayne800
Reply #356 on:
August 08, 2009, 12:15:25 PM »
Yeah, thanks Rob - I sort of figured around that.
Had a car turn in front of me. Managed to avoid the car but "buried" the bike in the process. Good thing is I bounced back up like an 18 year old
Just can't bring myself to go downstairs and look at the bike this morning though
Last Edit: August 08, 2009, 12:17:44 PM by wayne800
Jukie
I need a
Paradise
Reply #357 on:
August 08, 2009, 12:27:18 PM »
ooohhh Wayne very sorry to hear this. i know what it is like to have a car turn in front of ya. sending some kisses to ya to make you feel better
Before Honda CB125N
Suzuki GS125
Now. Ducati 620ie
Lambretta Li150
Ducati S4RT
mattyvas
Reply #358 on:
August 08, 2009, 03:29:20 PM »
Hey Wayne, did the driver hang around or just piss off and leave you with a damaged bike.
Sorry to hear about it.
www.mattvas.com.au
wayne800
Reply #359 on:
August 08, 2009, 11:30:40 PM »
Thanks Jukie, good to see you're back to your high jinks.
Yeah Matty she stopped & we swapped info. but I don't know if that helps - I'll see what QBE say. I'm flat out at work at the moment but I guess I have to make time to ride the bike over to Frasers to get a quote or whatever.
23
24
25
26
106
