Can't change Avatar
Started by Kopfjäger, September 21, 2008, 08:36:53 PM
Kopfjäger
darylbowden
Quote from: kopfjager on September 21, 2008, 08:36:53 PM
Hmm, I have no problem doing it.  Flounders, can you check and make sure the settings are correct for general users?  (sorry Kopf, I only have geek access)
The permissions all seem to be set so it can be changed.
It should work.
Slag
I am having the same problem. My avatar disappeared, and I cannot upload another one. When I try, it posts
"The attachments upload directory is not writable. Your attachment or avatar cannot be saved."
I have tried to link to an avatar that I have hosted, and nothing shows up. The one that I have hosted is 80x80, and only around 9k
darylbowden
Quote from: Slag on September 23, 2008, 09:01:02 AM
The linked avatar should be working fine.  At least it is for everyone else it seems.  I just changed permissions on the attachments folder, so try and upload again and see if that works.
darylbowden
I just tested the upload functionality and it seems to be working now. Please post up with your results.
Well, kopfjager changed his, so maybe it's working?
Slag
Kopfjäger
Quote from: Speeddog on September 23, 2008, 01:41:13 PM
Now I did.  [thumbsup] Working fine now. Thanks
