S2R Fuel Pickup Problem
Started by GOTJ, September 22, 2008, 11:05:33 AM
GOTJ
I have a 2007 S2R800. On a ride, my low fuel light came on. I rode another 15 miles or so and ran out of fuel. I could restart it and it would run for a short time at low throttle so I made it to a gas station. When I filled up, it took 3.0 gallons rather than the expected 3.6-3.8 gallons. Apparently the fuel pickup doesn't drain the tank. Any tips or solutions? Would this be a warranty issue?
scduc
This issuse has been discussed before. I infact had the same exact thing happen. The injectors can be damaged if they run dry. therefore there will always be fuel in the tank. I believe the the setting at the factory is at fault (but not sure). It doesn't make sense why there would still be over 1/2 gal.
