January 07, 2025, 01:15:26 PM *
Author Topic: Top mount Steering damper on S2r Dark?  (Read 6661 times)
JTMOTO
« on: September 25, 2008, 03:14:41 PM »
I have an 05 S2r dark and would like to know if it is possible to mount a damper on top, as I really dont care for the side mount option.   I have been lurking around for a while trying to figure this out but no luck.  Any help is greatly appreciated.
Bbrent
'08 S4RS Tricolore
« Reply #1 on: September 25, 2008, 03:27:10 PM »
There are alot of companies that make the top mounted damper. Do a search on this board.
Smokescreen
« Reply #2 on: September 25, 2008, 04:03:40 PM »
I was at Scott's a few days ago and asked about their Scott's (Ohlins) steering head mounted damper and was told they don't make it for the S2R 1K because on interference with the disabling system??  Anyhow, short story, they don't make it for that bike.  Check out their site for more info on yours.  Google Scott's performance
Catching a yellow-jacket in your shirt at seventy miles per hour can double your vocabulary.
Only a biker knows why a dog sticks his head out of a car window.
arai_speed
« Reply #3 on: September 25, 2008, 04:04:53 PM »
http://ducatimonsterforum.org/index.php?topic=1984.0
tangueroHondo
« Reply #4 on: September 26, 2008, 08:35:20 PM »
I thought the beautiful Bitubo made a unit for the S2R.Huh??
JTMOTO
« Reply #5 on: September 30, 2008, 02:22:12 PM »
Ok, just to let everone know, I ordered the Arrows damper and the kit does not work on "Dark" models.  I think my only option is the side mount.
Monstermash
AKA-TomColore
Interferiscalo se potete
« Reply #6 on: September 30, 2008, 02:55:21 PM »
 Why doesn't it work on the dark models? What the difference?
ute
I Have Titanium
« Reply #7 on: September 30, 2008, 05:19:53 PM »
it works fine on mine perfect fit
do a sarch on how to install
ROBsS4R
No matter where you go, there you are
« Reply #8 on: September 30, 2008, 05:42:58 PM »
They should. I have one on my S4R
JTMOTO
« Reply #9 on: October 02, 2008, 03:24:45 PM »
The reason it doesn't work is because the triple on Dark models is more like the 620 with the narrow bars and the height is different.  I took it back to the shop (Motovation USA) and they looked at it and called Arrows.  Arrows said that it has come up in the past, and they are aware that it does not fit dark models.  Refunded my money and I am starting over.  I do not know why it worked on your 06, maybe something different.  If anyone knows any other options let me know.  I need a damper, and I really don't care for the side mount but if that is my only option then so be it.
ute
I Have Titanium
« Reply #10 on: October 02, 2008, 04:44:31 PM »
here is mine  ii have now rotated to correct position
also works with the Suburban Machinery bars
it really makes no sense what your saying and what the dealer said ...i have seen 3 Darks from 02 up with Arrows Dampers
its a great damper
JTMOTO
« Reply #11 on: October 03, 2008, 08:08:47 AM »
What are those bolts ?  Those are not part of the kit I had. The bolts I had bottomed out about half way.  So I decided to use the shorter stock bolts and they worked (although not sure how many threads they turned) Just to see if that was the only problem. mounted the damper and it was at least 2 inches taller than the bracket.  Did you use the supplied posts that attach to your ignition?  That is the only thing I could think that might lower it into the correct position.  Does the damper sit level?
ICON
« Reply #12 on: October 03, 2008, 08:19:20 AM »
Use a matris damper then. They make one for the 620, should fit your Dark.
JTMOTO
« Reply #13 on: October 03, 2008, 11:26:50 AM »
I have emailed PJ's parts.  Is that the recommended Matris supplier?
ute
I Have Titanium
« Reply #14 on: October 03, 2008, 05:00:26 PM »
yes the damper sits level  now just  had to flip it
i lost 2 of  the  bolts that came with the kit ( gravel driveway ) so just grabed  a couple of metriic bolts i had laying arround
stock clamps
in the kit there ar 2 spacers for inbetween the clamp and the mount
the only difference between a dark and reg s2r is the 7/8" bar  this does not efect the way it mounts
