A semi-official 696/796/1100 exhaust thread
Started by Raux, September 28, 2008, 05:49:07 AM
GreasySnipe
Nice, I've been looking to replace my underseat exhaust. I've tried to get ahold of Motocreations for a set of Boomtubes but no joy on any feedback from them.
Quote from: nickshelby500kr on September 17, 2013, 07:06:25 PM
Don't know if any of y'all have seen this but it looks pretty damn good to me. Its a full system so I can't see why it wouldn't work for an evo. Its supposed to be pretty light too. Available from motowheels.
2011 Monster 796
2012 Street Fighter
2013 848 Evo
2016 Monster 821
2022 Scrambler Nightshift
2023 Triumph Speed Triple 1200 RS
2023 Monster 937 SP
Le Germain
Hi,
What's the weight benefit when fitting the carbon Termignonis compared to the stock exhaust?
G
EEL
New exhaust for the 1100 EVO. Sounds awesome! Only a slip on but still very surprised with the quality. Havent seen a lot of people with this one.
SC Project GP-M2
david3558
I bought a used 696 with Termi's - how can I tell if it's been installed with the ECU/Filter? Sorry if this question doesn't really make sense.
At slow speeds 1st and 2nd gear, I'm hearing a little backfiring when letting off the throttle.
2009 M696
Termignoni CF Exhaust
MotoDynamics Integrated Taillight
Atomic Fender Eliminator
TACstrat
If am upgraded ECU was installed, I believe the word "racing" will scroll across when you first turn the ignition.  Hopefully someone can confirm that is correct.
EEL
The best way is the remove the tank skin and lift the tank (and the overflow/ vent hoses). You'll be able the see the DP ECU and reference it by product code.
If you pull the airbox lid, you'll be able to see the filter type. Stock filters have an orange ring and paper filter media. I cant comment on what the DP filter looks like since I have a K&N.
This may sound like a lot of work but its only about 30 minutes time.
SpikeC
 I think that looking at the display is easiest. It will say if the kit is in there, it says Racing.
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
SteveO.
Just got mine back and had the Leo Vince slip ons tucked up and in against the bottom of the seat.  Looks a lot better than it did, and sounds great.  Too loud without the baffles in, so I'll probably install them soon. Pretty happy with the new look.
Before and after:
From the back:
zLoki
Looks great, share some details on what / how you had it done.  I have termis and this looks like a great next mod.
Mostly stock '12 796
Sold - '09 696 with 30,000 miles
SteveO.
Quote from: zLoki on March 19, 2015, 08:21:02 PM
I took it to a small, custom welding shop that does mostly high end cars, but dabbles in bikes and explained that I wanted the exhaust valve removed and the Leo Vince cans tucked up and in.  He did an amazing job cleaning it up and I'm really happy with the look.  I haven't ridden it yet as the roads are still covered with winter salt and gravel, but I can tell you it's ridiculously loud and shoots the occasional fire ball out the back when I blip the throttle.  I'm going to put the db killers back in and hope it quiets down a bunch, and go from there.  I also have a Duc ee valve eliminator on the way so I can completely remove the motor.  Right now, the cable is off and the entire valve assembly and y pipe was removed and I haven't seen a CEL light, but we'll see how that goes.
It's definitely "snappier" in sound and has better throttle response, but I do need to address the noise issue before I can ride it.
turboz32
#595
Not sure if this is mentioned as Ive seen a few posts about the SC Project Exhausts.
I wanted a GP style exhaust to eliminate the "moped" skinny tire/huge cans look I really disliked about the 696. (especially sitting next to my brother's R1) After a 2 month wait for a Spark exhaust that never showed I found that SC Project offered a low exit MotoGP style kit for the 796.  After speaking with G-Force out of Thailand they assured me that the 796 GP kit bolts up to the 696 without issue and sure enough they weren't kidding.  Bolts up with no issue*
*Okay there is a very minor issue and its that the O2 sensor out of the rear (top?) head interferes with the rear brake line.  I went to the local auto parts store, grabbed a Ti exhaust wrap and heat resistant sleeve and wrapped the pipe and sleeved the sensor et voila! no more issues.  Fits like a glove.  That stock system is a PITA to remove without removing the tank.
Pros:
Gets rid of the moped look
Loud as all hell
"can" is removable so you could probably switch to another slip on if you wanted to
Ti pipes turn a freakishly cool Blue color after heating up
Cleans up the back of the bike tremendously
Cons:
No Db Killer
Loud as all hell
Will require some sort of fuel modification or ECU flash (z-Fi, Rexxer, etc...)
O2 sensor on the mid pipe is kind of unsightly sticking up just in front of the rear brake lever/pedal (which is removable with the Rexxer Ive been told)
mr_wolf
Mine.. keeps some distance in the pipes to maximize the power curve through the RPM range. Sounds good without a baffle, loud enough but not obnoxious douchebag type loud.
Sammadams
Hello everyone, I've just joined the forum today, and my goal is to try and identify exactly what model of Leo Vince I am in possession of. Before anyone asks, NO I did not steal them, they were on the 2012 Ducati 696 that I bought on craigslist, which I have since totaled. So I am now trying to identify them to find out exactly how much they are worth, and I'm having trouble.
All I know is that they are some kind of SBK, which is all it says on the actual cans. So if anyone has seen these particular exhausts before, please, I am begging for any more information! Thanks in advance fellas
Leo Vince constantly updates their products.  SBK is an older model if I remember correctly.  You could try sending a photo to  infousa@leovince.com  I wouldn't worry much as long as I am sure of fitment.  They do make great exhaust.  A fair price compared to any quality brand and they should move quickly.
Charlie98
Nice looking exhaust... how did they sound on the 696?  Leos are on the short list for my 796...
Dennis
2014 MTS 1200S Pikes Peak
2013 M796 ABS
