A semi-official 696/796/1100 exhaust thread
Started by Raux, September 28, 2008, 05:49:07 AM
Saltash
Quote from: koko64 on July 03, 2018, 09:36:11 PM
[thumbsup]
You are correct to ignore the peak numbers and focus on the before and after curves.
What make/model dyno? Latest Dynojet dyno programme reads up to 10% lower than previous software on the same machine. Factory Pro dynos also read lower than previous generation Dynojet dynos. This is what industry insiders have told me.
Dynojet.
Cool.  [thumbsup]
There are different Dynojet models and even the same model can vary due to different maintence and software upgrades, etc. I have seen the numbers drop 10% or more due to new software, so even the comparisons on the same dyno only go back so far. After a period of time I have to add 10% to get the readings comparable over the years.
Zeus_R
Quote from: mr_wolf on November 25, 2016, 02:28:21 AM
Mine.. keeps some distance in the pipes to maximize the power curve through the RPM range. Sounds good without a baffle, loud enough but not obnoxious douchebag type loud.
Nice shot! Which exhaust is this?
The pipes look custom or modified oem. Great looking bike with a nice combination of mods.
How about this?
https://redirect.viglink.com/?format=go&jsonp=vglnk_162300261228210&key=7380040348cb056f0e988195afaf9852&libId=kpk2fnhl01000c6m000MLki7h0uvv&loc=http%3A%2F%2Fwww.ducatimonsterforum.org%2Findex.php%3Ftopic%3D78683.0&v=1&opt=true&out=https%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26source%3Dweb%26rct%3Dj%26url%3Dhttps%3A%2F%2Fwww.hsbkracing.com%2Fparts-and-apparel%2Fducati%2Fmonster-696-796-1100%2Fexhaust%2Fqd-ducati-monster-1100-evo-mid-pipe-servo-eliminator%2F%26ved%3D2ahUKEwjX8dSN7dTvAhWEzDgGHb_eD54Qqa4BMAF6BAgHEAU%26usg%3DAOvVaw3f7CPFUZ5-vaXc_J8Gotul&ref=http%3A%2F%2Fwww.ducatimonsterforum.org%2Findex.php%3Fwww%3Bboard%3D5&title=M1100%20Evo%20Exhaust%20Mid%20Pipes%20Without%20Exhaust%20Valve%3F&txt=https%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Burl%3Dhttps%3A%2F%2Fwww.hsbkracing.com%2Fparts-and-apparel%2Fducati%2Fmonster-...
https://redirect.viglink.com/?format=go&jsonp=vglnk_162300271447010&key=7380040348cb056f0e988195afaf9852&libId=kpk2hulc01000c6m000MLkiby6u28&loc=http%3A%2F%2Fwww.ducatimonsterforum.org%2Findex.php%3Ftopic%3D78683.0&v=1&opt=true&out=https%3A%2F%2Fwww.hsbkracing.com%2Fimages%2Fthumbnails%2F3008%2F3008%2Fdetailed%2F6%2FDSC_7583.jpg&ref=http%3A%2F%2Fwww.ducatimonsterforum.org%2Findex.php%3Fwww%3Bboard%3D5&title=M1100%20Evo%20Exhaust%20Mid%20Pipes%20Without%20Exhaust%20Valve%3F&txt=https%3A%2F%2Fwww.hsbkracing.com%2Fimages%2Fthumbnails%2F3008%2F3008%2Fdetailed%2F6%2FDSC_7583.jpg
