HELP,06 monster 620 wont start after turned on and off quicky
Started by erichan8757, September 29, 2008, 05:21:01 PM
erichan8757
i was just trying to start the monster,
i first start it and when the instrument is led i shut it off like right away,
cuz i was just gonna see something
then i started it again, this time it wont start now,
is it that the wire somehow burnt?
prior to that i bent the key , then i bent it back
and i use this key to start.
would it be something related to the immobilizer?
however i still hear the little sound, as you turn the key from off to on,
it'd normally have a sound,
the immobilizer light is still blinking, and i just finished riding for an hour of so,
so the battery is definitely good.
thanks for all views and replies,
i would be greatly appreciated it.
it's an emergency
thanks,
eric
07 GT1000
06 M620, [SOLD]
Modifications are never too many.
jdubbs32584
I'm really not sure of your timeline of events.
Have you tried turning hte bike all the way off (key turned all to the off position) and then turned it back on? Do the guages still sweep? Kill switch off? Tried the other key?
Do us a favor and try a different key-I'm suspicious of the bending.
erichan8757
i went home from school, i rode for about an hour,
then i was putting on the rack system from ventura,
then i accidentally bent my key cuz the rack doesnt fit well at the seat lock position
so i kinda twist my key there, and i twist is back then i wanna see if the key is working
so i put it in the ignition , then i turn it to on position then the cluster light went on and everything seen fine
then i shut it off and try to turn on again, cuz if seems to me that i cant turn the key freely as usual,
then the bike just die, however the immobizer light is still flashing, so i assum the battery is still good.
i also try the spare black key and the red key, it's still, not starting
thanks for the reply,
07 GT1000
06 M620, [SOLD]
jdubbs32584
erichan8757
07 GT1000
06 M620, [SOLD]
superjohn
I wonder if you triggered the immobilizer. Have you tried to go through the procedure in the manual to disable it?
erichan8757
#7
well i just go chek the bike and the immobilizer light is not even blinking now.
what should i do
07 GT1000
06 M620, [SOLD]
superjohn
Drat, couldn't log on for a sec. Also, check your fuses if nothing is coming on at all.
erichan8757
what kinda fuses>?? you mean under the fuel tank?
i am kinda new to this machanic stuff.
dun know where do start,
07 GT1000
06 M620, [SOLD]
erichan8757
07 GT1000
06 M620, [SOLD]
jdubbs32584
Ok, to summarize, cause I'm still having a hard time understanding.
Guages are no longer sweeping.
You've tried all three keys.
You've tried resetting it with the red key and the steps outlined in your user manual.
You're still hearing something when you turn the key to on.
Are all of these correct?
erichan8757
#12
i heard something when the first few time trying to restart it,
but after 3 4 time attempts it disappeared,
the ducati ny told me to reprogram all the keys ,
and it didnt work too,
now the immobilizer light is not flashing and i dont hear any sound as usual
07 GT1000
06 M620, [SOLD]
jdubbs32584
superjohn
Did you check your fuses? right hand side below the battery? I blew a fuse when I changed out my tail light and it wouldn't start.
