ok 1098 screwy again :P
Started by pipeliner1978, September 30, 2008, 05:13:18 PM
pipeliner1978
A little while back I was having serious issue getting into neutral, it would not go.  A friend came over and bled my clutch line, which resulted in a lot of air coming out, and some teeny tiny black specs from the master cylinder...........instant fix!  Now, lever is all mushy again, and it's barely actuating the clutch.  Bonwilder rode it to Hurst yesterday and said she had to hold in the brake and clutch while in traffic, or it would try and run forward on her, and she couldn't find neutral.  I just took it to the gas station and killed it twice because the clutch was so short.  You have to be on the throttle before even barely letting out on the clutch, or it will jump.....no play in it at all.  Where should I begin??!!??
bryant8
Hmm check the clutch slave cylinder for leaks
2008 848
26.2 done 12/5/2010
70.3 by 10/12/2011
140.6 by 12/31/2012
Slag
pipeliner1978
♣ McKraut ♣
i'd try bleeding it again, just to be sure.  that's about the cheapest thing to do to start with.
-  Dallas, TX
pipeliner1978
Quote from: ♣ McKraut ♣ on September 30, 2008, 05:33:39 PM
thanks, i think you're right.....
i dont know what kinda bike youre getting, but if its a i4, youre gonna need a new hobby, all that extra time youll have because youre not tooling.
♣ McKraut ♣
Quote from: pipeliner1978 on September 30, 2008, 05:38:17 PM
that's what i hear...
-  Dallas, TX
cdc
Tommy,
When we went to Arkansas, that was the problem I was having with the ST4S.  When I got home I bled the clutch and It is now working like buttah.
Bleed it again.  If it recurs, consider rebuilding the slave cylinder then the master cylinder.  I just had a conversation with RichD about the rebuild process.  He has a kit to rebuild the master cylinder.
cdc
pipeliner1978
Quote from: cdc on September 30, 2008, 06:48:19 PM
Tommy,
cdc
buttah is good [thumbsup]
I will bleed it again, if it continues to fail down the road, i'll pick up an after market slave.
pipeliner1978
Ronr
Quote from: pipeliner1978 on September 30, 2008, 06:55:38 PM
I think that's the way to go. Seems like a simple piece of hardware but they don't have a great reputation.
svoloch
sometimes just pumping the clutch will help
Werd.
Тише едешь, дальше будешь
2009 Streetfighter S
exes:
2006 Sh1t Hot Black Xerox 999     1973 BMW R75/5
2001 BMW K1200RS                     1994 BMW R1100S
1974 Guzzi T3                              1975 BMW R90/6
1975 BMW R90/S                         1973 Suzuki T500
pipeliner1978
Quote from: The Svoloch on September 30, 2008, 08:31:19 PM
Werd.
I know, but sometimes I get tired of winding my timepiece, but its so "buttah" when it tells proper time
cdc
Quote from: pipeliner1978 on September 30, 2008, 08:56:06 PM
tick tock!
cdc
cdc
Quote from: Bonwilder on September 30, 2008, 09:11:45 PM
all I know, is I sat in traffic for almost an hour - never getting out of first gear - unable to put the bike in neutral - I was kinda pissed, so when traffic finally started moving I contained myself at about 90, very politely splitting traffic and thinking f'it, just freakin pull me over cause I've got about 5 miles left before I have to park this thing in the garage. [thumbsup] [moto]
Bonnie,
I don't know if your clutch problem was worse than mine on the ST4S during the AR trip.  It was impossible to find neutral when I came to a stop but as I was rolling to a stop, if I had enough room, I was able to get neutral.  Bleeding the brakes solved my problem for now.  I'll have to ride it some more to see if the problem comes back.
cdc
