Calling Speeddog: Fuel line re-route on S4R
Started by DucHead, October 01, 2008, 05:03:09 PM
DucHead
Speeddog - you posted these pics on TOB, and I'm seeing if they show up here.  Nope.  Could you please derby them?
Also, did you need anything other than hose, clamps and quick disconnects?
Thanks,
  Dave
You need some Adel clamps and need to fab a small bracket, preferably with a rivnut.
I don't have access to those pics anytime real soon, I'll snap some more here in a minute.
Close-up of the small bracket to be fabbed, showing the 6mm rivnut:
2 pics showing where the regulator has been relocated:
Delivery line passing through the notch in the TB bracket:
Adel clamp holding the return line, held with a button head in the upper forward hole of the rockershaft cover, button head in the upper rear hole too.
Adel clamp holding the 2 hoses to the fabbed bracket:
General picture, all assembled:
Fuel line lengths are *crucial*.
Clearances are very tight.
Watch that the regulator doesn't chafe on the wiring going to the relays directly above it.
DucHead
Thanks Speeddog!!
I was gonna try to route the lines without moving the regulator, now I think I might just route things as per your pics.
Thanks again!!
Dave
DucHead
#4
Nick - thanks one million!!  The pics really made a difference!!   [beer]   [drink]
I relocated the fuel lines and rerouted a (new) starter wire.  It took almost 2.5 hrs.  The right side is much cleaner looking!   [moto]
Before:
After:
Ride it a bit and give the lines a careful inspection, make sure they're not rubbing on anything.
Don't want 'em to wear through.
Glad I could help.  :)
DucHead
Quote from: Speeddog on October 03, 2008, 06:02:13 PM
Thanks, will do.  I had it out this evening for a nice cool ride (in the low 60s here), and I'll check everything tomorrow.  BTW, I used the stainless quick disconnects from Omega this time.
