January 06, 2025, 07:25:36 PM *
Author Topic: Jetting FCR's  (Read 4730 times)
Some Dude
« on: May 09, 2008, 11:37:09 AM »
I'm trying to do this right now, and in the interest of getting some info about it on this site, I thought I'd start a thread and post a couple links i've found very helpful.  Please add any tips or tricks you may know
Thanks
http://www.ducatitech.com/2v/fcr_faq.html
http://www.keihin-us.com/tune.htm
http://www.factorypro.com/tech/carbkei.html
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
heads ported and polished
larger valves
new valves and cams
aluminum fly wheel & clutch basket
bacon        bacon        [
oppet
« Reply #1 on: May 13, 2008, 08:16:30 AM »
Those are good links.
If we tell the mods that has been done and what jetting we have. espesially if you have 944 kit, it may be hard to find correct settings, unless you try and try. Those jets aint cheap(1Xslow jet= 17,5 euro in finland)
I have pod filters, open frescos,m900,41mm fcr and I live at sea level
my settings are:
Fuel screw 3/4 turn
Slow Air Screw 1 turn
Float height 9mm
Main Jet 155
Main Air Jet 200
Slow Jet 60
Needle EMT
Needle Clip 4rd from top
And now it runs great.
greenmonster
« Reply #2 on: June 18, 2008, 04:38:58 PM »
Mine: 41mm`s, polished/matched ports, 900SS heads, 0.94mm squish, HC, TCI-P4 ignition, Dynas, SilMoto high.
Settings:
Fuel screw 1,25 turn
Slow Air Screw 1,5 turn
Float height 9mm
Main Jet 162,5
Main Air Jet 200
Slow Jet 60
Needle EMT
Needle Clip 3rd from top
FCR are very sensitive to sync.
« Last Edit: June 25, 2008, 04:55:48 PM by greenmonster » Logged
M900 -97
MTS 1100s  -07
m9hundo
a.k.a. gil
« Reply #3 on: June 25, 2008, 02:30:11 PM »
I just picked up some FCR's in a trade. The thing is they're 39's and I have a 99 900. Mods are 2 into 1 exhaust and pod filters. Any suggestion guys? I know 41's are in order but was told that I could make these work.
Thanks - Gil
whats moepery? moepery is when you expose yourself to a blind person.
greenmonster
« Reply #4 on: June 25, 2008, 04:57:55 PM »
My friend w a M900  -98 w 750 heads had 39`s, they worked excellent.
Dunno his jetting unfortunately.
M900 -97
MTS 1100s  -07
printman
Check out my a.....
« Reply #5 on: June 25, 2008, 05:43:32 PM »
on a 93 900 SS and 41's
have:
58 slow circuit, air screw at only 1 turn, 4th clip on needle (1 down from center) and stock 155 main
not the 39's but maybe a benchmark
I'll update this later at a convenient time Thank you for tuning in.....
dlearl476
« Reply #6 on: June 25, 2008, 08:16:03 PM »
Thanks - Gil
I'm sure you can.  They'd be  better on a 750, but for street riding I think they'd be fine.  I'd suggest you pick Chris' brain at CA-Cycleworks.
m9hundo
a.k.a. gil
« Reply #7 on: June 25, 2008, 08:55:46 PM »
I shot chris an email but from what I've heard he's a pain to get a hold of.
knightrider
« Reply #8 on: June 25, 2008, 09:14:29 PM »
email is prolly the best way to reach him, lets just say hes got lots of little projects. and me stopping by annoying him by asking him questions, oh and spending money Cheesy
1994 M900
m9hundo
a.k.a. gil
« Reply #9 on: June 27, 2008, 07:10:53 PM »
I have a issue with the 39 FCR's.  I plugged in the fuel line and clamped it down HARD and theres fuel leaking at the junction. WTF? is there a seal or something missing here.
TIA - Gil
dlearl476
« Reply #10 on: June 28, 2008, 06:50:00 PM »
Then add in my dumb questions and his inbox gets pretty full.  He will get back with you.
About your leak, take a look at an exploded view.
http://www.motorcyclecarbs.com/keihin/frames/FCRDframe.htm
Lots of O rings in there.
« Last Edit: June 28, 2008, 06:52:05 PM by dlearl476 » Logged
