definitive SSS chain adjust ?
Started by ute, October 06, 2008, 06:59:07 PM
ute
so i have always just loosened the 2 top bolts on the axle and adjusted
but have been reading on the DOCC site about peeps who have broken / damaged the cam adjuster by not loosening the axle nuts ( the big ones on the side of the axle that hold the axle in place )
they say you should
so whats the word yea or nay on this
Heath
QuoteAdjusting chain tension
Move the motorcycle slowly until
finding the position at which the chain
is tightest.
Place the motorcycle on the side
stand.
Push the chain upwards with one
finger at swingarm mid-length (see
label).
The lower length of the chain should
have about 30-32 mm slack.
If not so, rectify as follows:
Loosen the two screws (1) securing
the rear wheel hub to the swingarm.
Apply the pin wrench (2) part no.
88713.1038 so that it engages a
sector of the eccentric hub.
Rotate the eccentric hub until
achieving correct chain tension.
Rotate counter clockwise to tension
up the chain; rotate clockwise to
slacken (when viewed from chain
side).
I don't see anything about it in the workshop manual.
2007 Ducati Monster S4RT
aaronb
that makes no sense.  there is no connection between the axle and the swing arm.  just do the two bolts, you'll be fine.
Milwaukee, WI
'07 s2r1k, '81 honda cb400t
brimo
Quote from: aaronb on October 06, 2008, 08:31:37 PM
ditto... the c spanner should need very little force to turn it.
From a story by RAT900
desmoworks
Quote from: brimo on October 06, 2008, 09:49:01 PM
exactly - not sure why you would need to loosen the axle nut - it has nothing to do with it.
Anthony Creek
Pro Italia Online || mota-lab
Jeff_S2R1K
I watched two Ducati mechanics tighten my chain and they loosened the 46mm nut that holds the wheel on.  I don't know why. :-\   As stated above, it doesn't seem like it has anything to do with tightening the chain.
Capo
Quote from: ute on October 06, 2008, 06:59:07 PM
they say you should
Cam adjuster? I think there is some confusion between a SSS and a DSS. The SSS does not have cam adjusters. It would be impossible to rotate the eccentric hub without loosening the bolts that clamp the swing arm to it.
Capo de tuti capi
RB
Quote from: Capo on October 07, 2008, 04:08:04 AM
+1
Munch
Quote from: Jeff_S2R1K on October 07, 2008, 03:51:01 AM
Time to find a new mechanic!
ute
great response guys
thats what i have been doing
just wasn't sure if there was a "cam" inside the esentric hub
thanks
aaronb
Quote from: ute on October 07, 2008, 05:00:48 PM
great response guys
thanks
no cam in the eccentric.  just a big ol' chuck of aluminum with some bearings pressed in.
Milwaukee, WI
