Are they kidding me?
Started by JTMOTO, October 10, 2008, 01:19:44 PM
JTMOTO
So I start to mount the Ohlins damper which should be a 5 min job right and what????  Remove front fender? The brake calipers and the front wheel!! Then loosen the handlebar and triple clamp bolts for the fork leg OMG!!! Then slide the clamp blah blah blah.  Who's the rocket scientist that designed this thing.  Why not just make it two pieces????
Qfactor
it's  piece of crap...
I'll take it off your hands for a generous $23.62 shipped!
Q [bacon]
Ducatiloo
Quote from: Qfactor on October 10, 2008, 01:36:27 PM
Q [bacon]
He's ripping you off!
I'll pay for shipping.
750 SS 01    800 S2R 05  Aprilia RST 1000 futura
Quote from: Ducatiloo on October 10, 2008, 01:37:05 PM
they're both ripping you off!
Ill pick it up!
Ducatiloo
Quote from: He Man on October 10, 2008, 02:49:29 PM
Ill pick it up!
I'll pick it up, buy you a beer and wash your bike.
Quote from: JTMOTO on October 10, 2008, 01:19:44 PM
You can buy a split clamp.
Quote from: ducpainter on October 10, 2008, 03:23:13 PM
The rest of that story will have to wait until..................
Quote from: stopintime on October 10, 2008, 03:26:37 PM
...my ribs don't hurt so much.  ;D
BCM sells them..not sure who makes them.
OverCaffeinated
You gotta loosen both forks at the triples and slide forks down, then slide clamp over fork. Easy if you have a lift that picks up the bike by the lower triple, but not five minutes easy.
Quote from: JTMOTO on October 10, 2008, 03:41:45 PM
http://www.bcmducati.com/index.php
These guys?
Yes...
they don't do much online.
Give them a call. 603-524-4898
They'll ship anywhere, although their shipping charges are high IMO.
It also would not surprise me one bit if one of the sponsors here has the clamp you need also.
Quote from: OverCaffeinated on October 10, 2008, 03:46:36 PM
You only need to loosen one. It's not that difficult if you have a means to lift and support the bike. It does require front wheel removal.
JTMOTO
Thank you, that will be much easier.
Quote from: ducpainter on October 10, 2008, 03:52:24 PM
Yes...
If you loosen both and lower both forks, you don't need to remove the wheel...
squidwood
either way I would remove the front fender first. [thumbsup]
They can be damaged quite easily.  [bang]
The whole job is easy and quite starightforward.
I would say no more than 30-45 minutes start to finish.
After you can do this----> [drink]
JTMOTO
Thanks ducpainter!  $38 bucks and its on it's way.
Quote from: ducpainter on October 10, 2008, 03:33:11 PM
