What's the advantage of upside-down forks?
Started by mstevens, May 09, 2008, 05:30:52 PM
mstevens
Clearly, I'm no technical whiz! I've tried searching the web, but all I can find is descriptions of upside-down forks but nothing about what makes them better.
So, what's the deal with them?
Stiffer, stronger.
When they were originally developed for MX, it was the only way to get sufficient travel (12") and still have enough overlap between the tube and slider for stiffness, yet not have a whole bunch of fork stuff hanging below the axle.
ScottRNelson
The biggest advantage is that they're way stiffer than the other kind.  You used to always see motorcycles with fork braces that held the bottom tubes in place so that the forks couldn't flop around so much.  That is not needed with the upside-down or male slider fork.  You also have a little bit less weight moving up and down along with the front wheel.
The extra stiffness is a big improvement over the way things used to be.  That and radial tires produces much better handing motorcycles now.
I think the correct term is "less unsprung weight" (forreigner :P). The wheel will move easier up and down without also moving the weight of the damper/suspension. This makes for better/more even contact with the ground = safer ride. Feel free to correct me if I'm off :)
mstevens
Thanks!
So, stiffer and less unsprung weight. Got it.
The easiest way to see why they are stiffer is that all the bending stress is up by the triple clamps.  There is no bending stress near the axle.  So, upside down forks but the largest cross section (largest diameter) up in the bending stress area.
Alex
Quote from: mitt on May 10, 2008, 11:57:55 AM
Cool, I'd never thought of that part.
Aftermarket: RoadRacing modified under-engine exhaust, revalved 996 forks, ProCutting half-open clutch, CC triple and pressure plate, 999 clipons, BMC filter, CRG-LS mirrors, PC3, Rizoma rearsets, heated grips, +2 teeth in rear gearing, Veypor VR2 computer, MBP collets, Yoyodyne slave, Galfer waves front and rear, misc CF (mostly faded), CRG clutch/brake levers.
hypurone
teddy037.2
cool beans! I was just talking about this w/a buddy of mine today on a ride...
we both had no idea...  ;D
Lord_Bragle
Human legs are a bit like upside down forks I always think, slender components in the lower sections like ankle joints and shins bones and thiker (thighes) and with much stringer joints (knees and hips) in the upper areas, less knee knock proly equates to less fork flex lol, what do I know  :D
