January 07, 2025, 01:12:46 PM *
Author Topic: Heated Grips  (Read 4139 times)
russelson
« on: October 13, 2008, 12:36:56 PM »
With the temps starting to drop, what recommendations do folks have for heated grips?  This is for a M696.
crazy bike girl
aka msincredible
« Reply #1 on: October 13, 2008, 12:46:56 PM »
Dual Star heated grips
greenmonster
« Reply #2 on: October 13, 2008, 02:15:24 PM »
Had similar to http://www.dual-star.com/index2/Rider/heated_grip_kit1.htm on my bikes f years.
Best 30 bucks I`ve spent on the bike!
Very easy installation, too.
« Last Edit: October 13, 2008, 02:17:28 PM by greenmonster » Logged
M900 -97
MTS 1100s  -07
scduc
« Reply #3 on: October 13, 2008, 03:06:59 PM »
How do you get the grip on over the top without ripping all to pieces?
« Reply #4 on: October 13, 2008, 05:32:29 PM »
what do you mean
edit.
OOHHH!!! you mean how do you put it back onto the bar.
Compressed air. the air expands it and puts an layer of air and slides right on without effort at all.
« Last Edit: October 13, 2008, 05:42:16 PM by He Man » Logged
Old_and_slow
« Reply #5 on: October 13, 2008, 05:35:38 PM »
Easiest way to get grips on or off is with compressed air.  Just use a nozzle at the inside end of the grip...it inflates it a bit and lets you slip it on or off easily.  Old trick for motorcycles and bicycles.  Might even work on wheelbarrows, for all I know.
For $50 you can touch my
« Reply #6 on: October 13, 2008, 05:46:29 PM »
When I did them, we wanted to swap out grips anyways, so cut the old ones off, and then the goo used to adhere the new ones also acted as a lubricant to slide them on.
greenmonster
« Reply #7 on: October 13, 2008, 06:20:23 PM »
I use little dish washing liquid to slip them back, works good.
Sameoff actuelly: Lift rubber w screwdriver, pour it in, work off.
M900 -97
MTS 1100s  -07
vwboomer
« Reply #8 on: October 14, 2008, 08:32:27 PM »
I put the Dual Stars on my bike last year. And they are better than nothing. Great for the price really. But last weekend my hands were getting pretty cold at 45 degrees. We rode about 2.5 hours, stopped, then another 2.5. FWIW I had Underarmor glove liners and my Teknic gloves on.
Aerostich also makes an economical heater that velcroes over your existing grip that has fair reviews.
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
« Reply #9 on: October 14, 2008, 09:01:17 PM »
maybe your high is defective? becasue mine on high are too hot to touch. even at 30 degrees.
lemond
« Reply #10 on: October 14, 2008, 09:08:35 PM »
You should also add a pair of handguards to shield your hands from wind.
2000 GSX-R 600 Track Bike
1995 Ducati Monster M900
vwboomer
« Reply #11 on: October 15, 2008, 08:53:03 AM »
It's possible. The low seems to put out more power but I figured I just got the  connection backwards. I'll have to check it out, tho the end of the season is almost here unless I get a new battery.
2005 GasGas FSE450
2004 Honda VFR
