696 check engine light.
Started by be350ka, October 14, 2008, 05:53:26 PM
be350ka
Before I took my bike in for the 600 mile check I experienced a "flash" of the check engine light. When I got home I turned the bike off followed by turning the key on to enter the ERROR page. Nothing appeared. I called the shop to see what I should do and they said that they would look at it when I brought it in in a few days.
Well, in the last two weeks it has happened another 2 times. The first time the techs told me that there was a soft code for the Lambda sensor, but nothing hard. The second time it happened I talked to another tech and he didn't seem to excided about it and said if its not staying on keep an eye on it.
Tonight, after lubing the chain, I went for a quick ride and the check engine light came on for about 2 or 3 seconds and then went off with no change in engine power or any other indication of an issue.
So, has anyone else been having this problem? I am going to call the shop in the morning. What should my next step be? I can only assume that these repeat "flashes" are the same as the first. The bike now has 1300 miles.
jakem696
Did you find out more about this?
Jake.
09 Dark M696
    Tail chop
    Full Termis exhaust Kit
    14t front
    CRG Bar end mirror
    Woodcraft Rear set
    Belly Pan
88 Honda VFR400R(NC24)
90 Honda VFR750R(RC30)
check the wiring on the vertical cylinder O2 sensor. mine has developed a small scar where it was supposed to clip onto tht ebottom of the fuel tank to keep it off the exhaust pipe. I tied it up away from both to avoid any rubbing and any more damage.
