January 09, 2025, 11:57:04 PM *
Pages: [1] 2 3   Go Down
Author Topic: Speaking of Rectifiers...  (Read 5516 times)
SR1K_Femme
TWINS Basil, TWINS!!
« on: October 15, 2008, 07:06:15 AM »
So my buddy who has an S4R, had the pleasure of being stranded in the not so friendly outskirts of eastern Cali, when he lived there.  Apparently the rectifier tends to get a might warm under the seat and fries itself.  Has this problem been fixed, or should I be concerned.  Alas I've had this happen to me with my CBR (and no they haven't updated, in the last 15years. Roll Eyes)  And I REALLY don't want it to, on the Duc.
"Why, so serious!?"
Mother
« Reply #1 on: October 15, 2008, 07:17:47 AM »
I've always heard second and third hand about the under seat location of the rectifier being bad news
never seen one actually fail
TPO Parts makes a slick little kit to get it some air
radically over-priced if you even have rudimentory skills with a hacksaw and a drill motor
but the fit and finish more than make up for it IMO
Vic has one I think
NEIKOS
« Reply #2 on: October 15, 2008, 07:28:36 AM »
I wouldn't say mine "failed" but the connectors did melt through - don't believe me you can ask Bible Boy, he helped me fix it.
It is now relocated.
Visolara
Jacobs Love Meat
« Reply #3 on: October 15, 2008, 07:36:17 AM »
It is now rectified.
fixed it for ya.
Maurice Miller
2009 OMRRA Rider Representative
OMRRA #39
WMRRA #39
Dark Horse Racing
Race Supporters -
Noel Communications, Inc. , 2Fast Motorcycle Track Days & Instruction , KBC Helmets , EDR Performance , Cascade Tracktime , GP Suspension North , KFG Dunlop LLC , LP Privateer , Dainese , AMS Oil
| 2006 Ducati 749S (street) | 2004 Suzuki SV650S (race) | 2002 Aprilia Mille (race) |
NEIKOS
« Reply #4 on: October 15, 2008, 08:06:35 AM »
I so want to throw out a rectum joke but my little brain just can't make the connection . . .  bang head
scott_araujo
« Reply #5 on: October 15, 2008, 08:55:16 AM »
If you're not in the mood to go through relocation, getting more air, etc. you can just trace the wires from the rectifier down to the nearest juntion connectors.  Clean the terminals and put some dielectric grease on them.  This keeps them from corroding, keeps the electrical resistance down, and helps keep the temps down.
That said, under the seat with no airflow is a stupid spot to put something with cooling fins that tends to get hot.
Scott
SR1K_Femme
« Reply #6 on: October 15, 2008, 09:51:04 AM »
Cooling fins, what?!  We don't need no sticking air flow to make those actually WORK do we?!  Tongue  I hear ya guys!  Not sure I want to part with a bunch of money on my Duc for a 'relocation' kit, when I can buy 'cooler' things. Wink  I'm thinking I'm going with Scott's idea for now. Hey Neikos, next time you ride or whatnot, can I check out your 'rectified' rectifier?
"Why, so serious!?"
duc_fan
« Reply #7 on: October 15, 2008, 11:08:30 AM »
Effin' Ducatis and their bloody electrics.  Roll Eyes
Ducatis are like Ford when it comes to electrical stuff: crappy connectors and weak wiring.
+1 to what Scott said about thoroughly cleaning the connectors and coating them with dielectric compound.  The connections on Chuck's bike had to be replaced because the OEM one had melted so badly the wires were coming loose (actually, one was completely disconnected when we got in there).
The headlight on my SS melted its connector last year.  That's okay, it gets better... when I hit the high beam, it's not shutting off the low beam filament.  I need to double-check the Ducati manual, but from what I understand of headlights, this ain't normal.  Running both filaments draws too much power and gets the bulb too hot.  So... the switch is probably bad.  I'd just not use the high beam, except that riding down Stafford Rd at 11pm is pitch-fricken-dark, and the low beam just doesn't cut it.
Anyway, Sabrina, if the rectifier is under the seat I'd put it on the priority list to get it relocated, whether you do it yourself, have one (or more) of us do it, or buy the kit.  Cleaning the connector is a stopgap measure.  It helps, but it's probably not the long-term fix.
NEIKOS
« Reply #8 on: October 15, 2008, 11:09:39 AM »
Sure.
scott_araujo
« Reply #9 on: October 15, 2008, 03:28:11 PM »
Dan, yeah, only one filament on at a time.  The exception is the passing trigger which flips on the high beam and does not dim the low beam.
Femme, you could also just cut off the connector and chuck it, solder the thin in place.  I think LT Snyder recommedns this as a fix in his manual because of the crappy connectors.  I like that guy's manual, he knows his doo-doo.
Scott
NEIKOS
« Reply #10 on: October 15, 2008, 03:37:29 PM »
. . . just cut off the connector and Chuck it, solder the thin in place.  I think LT Snyder recommedns this as a fix in his manual because of the
Hey now!  Shocked
krolik
Yeah, that's me. So what.
« Reply #11 on: October 15, 2008, 06:15:27 PM »
I have the TPO relocator, it's a nice piece, and it is easy to install. waytogo
Quote from: SacDuc
SR1K_Femme
« Reply #12 on: October 16, 2008, 06:52:37 AM »
How much is said TPO relocator?  Or dare I ask!?   Shocked
Damn electronics!!  *puts fist in the air, shaking angrily*
"Why, so serious!?"
ryandalling
Trade you my milk for your Ducati...
« Reply #13 on: October 16, 2008, 09:10:39 AM »
Jump starting your bike from a car (a running car) will fry your voltage rectifier/regulator too.
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
SR1K_Femme
« Reply #14 on: October 16, 2008, 09:50:50 AM »
Good thing I haven't tried that yet then eh?  Wink  Thanks for the heads up!
"Why, so serious!?"
Pages: [1] 2 3   Go Up
