The Official S4 Fogarty thread: please post if you own a Foggy or have input
Started by hydra, May 09, 2008, 07:38:07 PM
MonsterMan1036
Alex Ortner 1036CS
1036 Foggy Monster (sold)
Commonwealth 848 track bike
1199 Tri
MonsterMan1036
Alex Ortner 1036CS
1199 Tri
MonsterMan1036
Alex Ortner 1036CS
1199 Tri
MonsterMan1036
Alex Ortner CF kickstand
Alex Ortner top triple
Lost a horn and moved the other one here.
Alex Ortner 1036CS
1199 Tri
hydra
hey monsterman,
great stuff man! could you give us your impressions of the new swingarm? unless of course you haven't had enough seat time on it yet...
but in any case, were you able to just plug and play or did you have to modify anything connecting to the frame? but i'm guessing nothing as involved as fitting that 996 SSS like magnus did. after seeing yours and magnus' swingarms, i'm really, really diggin the cleaner and sportier look.
but for your larger displacement engine it was probably a practical decision to have an upgraded suspension system, no?
russ
S4 Foggy- tires, battery...
BE WATER
MonsterMan1036
Quote from: hydra on May 19, 2008, 06:08:22 PM
Had shitty weather this weekend and had some work to do on my other bikes, no new ride report. [bang]
The Moto Corse swing arm is a direct swap, the only thing is you may have to adjust your ride height, because the escentric for chain adjustment will affect it. I still need to raise the rear a little more to get it back to 1" over stock in the rear, I'm also going to drop the front around 2mm.
Yes, it was a practical decision on the suspension. I think that having the suspension set to you and your riding style is the most important mod you can do.
Did you decide what your doing with your mod budget yet?
Alex Ortner 1036CS
1199 Tri
foggy123
Quote from: Magnus on May 19, 2008, 09:57:35 AM
Is this who I think it is???
What will the pods get me?
Not sure who you think it is but probably the same person.   [beer]
Pods= less weight + cooler look (subjective) and same hp.
easy mod.  Get filters, remove air box, cut or mill your velocity stacks, reinstall stacks with pods.  Only downside is the rush of intake noise  that any hooligan should enjoy.
Come June a new monster motor is being built.  St4s+1000 crank+ 506 cams + MBP 916 heads + Motocreations exhaust = S4X
Magnus
Quote from: foggy123 on May 21, 2008, 06:36:17 PM
good to hear from you rick, i figured it had to be you but i wasn't sure...   do you still have the foggy?  is that motor going in the foggy or something new?
'02 MS4 Black Fog
duc996
       "Monster S4r"
       "KTM SMC 690"
Big Troubled Bear
Monsterman and Magnus, those are some of the best looking Ducati`s I have ever seen [thumbsup]
foggy123
Quote from: Magnus on May 21, 2008, 10:11:06 PM
I still have the foggy.  I tried to sell at one point but nobody wanted it so taking it to the next level.  Mark S.  has it right now for some part fitting and mock ups.  Engine is for the bike.  Should be fun when done.
Juan
monsterman1036 lots of carbon even on the stand :o, sweet ride..!
Monstermash
As you guys already know, I'm a HUGE Foggy fan.
I came across this over on Speedzilla and almost threw up. Then I saw that he put them on a Foggy, and I did throw up!!!!!  [puke]
Check it out: http://www.speedzilla.com/forums/ducati-monster/44122-2002-ducati-monster-s4-swingarm-extentions.html#post481311
Someone should hunt this guy down and beat him to death!!!
hydra
Quote from: MonsterMan1036 on May 20, 2008, 08:45:42 AM
monsterman,
i wish the stock swingarm wasn't so damn ugly because for my 140lb frame it does an adequate job. but for now i'll be upgrading to some penske's for the rear and race tech revalve for the forks. i'm still deciding on what to do with the beer tray and what mirrors but the MM ears are really starting to be an eye sore  :P. so i'll be replacing those ASAIC.
i did get my 18k servicing completed. the guys at Pro Italia did a great job IMO. so my valves are done, all fluids changed including brake fluids, new rear pads, fuel filter, sync'd TB's and replaced one flaking rocker. also, i had the belts replaced along with the chain.
i put a new sprocket on the front (it was worn) and went from a 37t to a 39t for the rear. this has made a big difference in the lower range. the bike feels even better in the twisties and roll ons are pure heaven!
BE WATER
Cucciolo
WOW>>> The Custom BoomTubes give the bike a minimalist look. That and a tail chop ..... I would like to do this on my S4R ..  where can I get those pipes? I bet they are loud as hell.. YOU HAVE A UNIQUE BIKE>>> CONGRATS [thumbsup]
