January 09, 2025, 11:43:21 AM *
Pages: 1 [2]   Go Down
Author Topic: windscreen stabilizer  (Read 6110 times)
DucLeone
« Reply #15 on: October 20, 2008, 06:08:51 AM »
i use to be a booblehead on higher speeds ,becouse of the flex of the screen ,now the screen is solid and what a difference!!
Money well spent
DUCATI NON E UNA MOTO, E UN STILE DI VIVERE
KISS FRENCH AND RIDE ITALIAN
S2R 800 Black
Privateer
« Reply #16 on: December 28, 2008, 01:34:35 PM »
I got these as a christmas gift and I can only echo what has been said above.
Made a big difference at highway speed.  When I first got up to 60-70, the airflow was so different that it threw me off.  I think it's hitting me more up around the helmet.  Before, the airstream was hitting me in the neck.
The improved airflow also dramatically cut down the wind noise I was getting in my helmet.
Andy
S2R 800 '07
« Reply #17 on: December 28, 2008, 03:36:24 PM »
There is an alternative to PoorDucRider   http://www.matrixmotosports.com/products/ducati-carbon-fiber-fairing-support-stays
scduc
« Reply #18 on: December 28, 2008, 05:20:41 PM »
I got a set of the Matrix ones for Christmas, wont be able to put them use until March, I think they look better then the poorduc style. On my older Monster the fairing slapped the instrument panel. I have not noticed it yet on my 08', but I do see it flapped around so this mod wil definately fix it.
Alexandre
Monstro
« Reply #19 on: December 29, 2008, 04:29:48 AM »
Perfect  Cool
madalf71
relaxing at home
« Reply #20 on: December 29, 2008, 11:17:45 PM »
My 2cents worth, just some different colours, see link.
http://ducatimonsterforum.org/index.php?topic=16294.0
Cheerio all
Madalf
geoffduc
18 till i die
« Reply #21 on: January 07, 2009, 10:30:04 AM »
Top marks to PoorDucRider  applause
Simple is efficient  waytogo
2015 scrambler FT
2009 monster 1100s
Goat_Herder
« Reply #22 on: January 07, 2009, 10:55:33 AM »
The stablizer from PoorDucRider seems like a good idea.  But is it just me or is it just a matter of going to HomeDepot for some metal bars/strips and bending them yourself?
Goat Herder (Tony)
Privateer
« Reply #23 on: January 07, 2009, 08:30:02 PM »
pretty much.  But how much is your time worth over the pretty inexpensive PoorDucRider supports?  First I'd have to find appropriate bar stock.  Then the amount of time i would spend getting one side perfectly bent, then doing a mirror image for the other.. then getting them painted or powder coated... I'd rather just pay the $35 and have it done with.
Andy
Goat_Herder
« Reply #24 on: January 08, 2009, 01:03:33 PM »
I guess I am just one po duc rider.  LOL  Found a 3' piece of 1/8" zinc plated metal strip at Home Depot for $5.  I think I can mess around in the garage for an hour and make the supprts myself.  Beats sitting on the couch, rotting my brain.  Besides, it's fun getting your hands dirty.
Goat Herder (Tony)
S2R 800 '07
« Reply #25 on: January 08, 2009, 01:32:20 PM »
Remember to get some longer bolts, at least for the upper connection. Post pictures when you're done? Good luck waytogo
I'll be here on my couch, rotting my brain laughingdp Already have the PoorDucRiders Grin
« Reply #26 on: January 08, 2009, 07:59:53 PM »
HD sells aluminum barstock VERY similar to the PDR supports I have. To have them bent to the perfect angle and pre-drilled makes them worth the price for me...
Goat_Herder
« Reply #27 on: January 11, 2009, 09:56:13 PM »
Well, it did took me longer than an hourto make those brackets.  Trial and error took a little longer than expected.  But in the end, they turned out decent, in true po duc rider fashion.  These are some pics I took along the way.
1.  Taped a couple strips of cardboard for measurements and mock up.  Total length needed is 8 1/4", with 2 bends (40 and 50 degrees)
2.  Bought a 3/4 inche 3 foot long aluminum strip from Home Depot for $5.  Made the cut for proper lengh and bent the piece with a vice and clamp.
3.  Making the second bend
4.  Twist the end and bend slightly to meet the windscreen.  Drilled the holes and rounded the corners.  Repeat and make the mirror image
5.  Checking for size and fit with longer bolts ($2)
6.  Final fitting on my M620.  I know the finish is not the greatest and they are not as "well made" as the pre-made ones you can buy.  But they put a smile on my face every time I see them, knowing that I made them out of nothing. Grin  It's one of the kind!  Planning on painting the brackets and the fairing yellow to match the tank.
Goat Herder (Tony)
S2R 800 '07
« Reply #28 on: January 11, 2009, 11:30:05 PM »
Congratulations waytogo
I know the feeling of self made. Not that I do it all the time, but nevertheless.
BTW - yes/maybe on the yellow paint brackets - definitely no on the yellow fairing (IMO)
Goat_Herder
« Reply #29 on: January 12, 2009, 11:48:55 AM »
Hmmmmm, interesting that you would keep the fairing flat black on a yellow M620.  I thought it's looking a little weird with a mix and match fairing.  Anyway, I do like the aluminum/metal look of the bracket.  I might probably end up polishing it or paint it to match the frame...
Goat Herder (Tony)
Pages: 1 [2]   Go Up
