January 08, 2025, 09:03:48 AM *
Author Topic: Swingarm Spools?  (Read 6544 times)
Ranger06
« on: October 18, 2008, 01:20:09 PM »
Just completed another round of mods.  Installed a SpeedyMoto top triple, seat cowl, clear alternatives integrated tail light, shock sock, and cored my cans.  My question is this, what are my options for swingarm spools?  My bike has spent a decent amount of time with my Pitbull stand under it so I was thinking, spools would be easier than the flats for the next round of mods.  Is there such a thing as spools that bolt on through the axle, like a slider would?  Thanks
2008 695 Dark
weemonster
weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #1 on: October 18, 2008, 01:40:09 PM »
what bike do you have?
Cos ones with aluminium swing arms have lugs for stand fittings built in to them.
« Last Edit: October 18, 2008, 01:41:57 PM by weemonster » Logged
Ranger06
« Reply #2 on: October 18, 2008, 02:12:29 PM »
Its an 08 695.  No threaded holes in the swingarm Angry
2008 695 Dark
Cider
« Reply #3 on: October 18, 2008, 04:45:23 PM »
I've never seen ones that go through the axle, but you could drill the swingarm and use the press-in bungs, or just bolt the spool on the inside (suggested to me by PitBull).  I had some bungs welded onto my swingarm, which is probably the sturdiest way to do it, but it's a lot of effort (picture below).
No matter which method you use, make sure you carefully locate them so your stand doesn't interfere with the exhaust or rear axle.  Also, if you have low mount cans, make sure they won't hit the spools when the suspension is compressed.
Ranger06
« Reply #4 on: October 18, 2008, 04:59:19 PM »
Welding on the bungs seems like the best option.  Where did you find a "bung"?  I really like how you have yours set up.
2008 695 Dark
« Reply #5 on: October 18, 2008, 05:38:41 PM »
there are swingarm sliders with spools that go through the axle.
check out the sponsors to the left <----------
sponsors: can i get a bigger discount now?
Sleeper_I
cannot raise his
Live free and ride hard
« Reply #6 on: October 18, 2008, 08:04:13 PM »
Yep, check out http://www.motovationusa.com/mvstore/Scripts/prodList.asp?idCategory=83. Motovation's swingarm sliders which are bolted on through the axle are also doubled as spools.
Here's mine, sorry it was late at night:
« Reply #7 on: October 18, 2008, 08:57:53 PM »
the ONLY thing about that type is you can't remove the rear wheel. but it's cool they have dual use. they should have drilled and tapped holes for spools on the 696.
btw you need to get the bar end sliders to complete the set.
Sleeper_I
cannot raise his
« Reply #8 on: October 19, 2008, 02:55:24 AM »
Grin Currently my toy allowance wouldn't allow me to get any bar end sliders. Besides I'm saving my allowance for better mods. Evil
Raux is right, you can't remove the rear wheel with this type of spools/sliders.
As you can see I have a Pit Bull forward handle rear stand with interchangeable plates. I can remove the spool plates and install the standard plates for any wheel removal work.
So if you are planning to do a lot of mods that requires you to remove the rear wheel often then I would suggest getting a set of spools installed the good ol way. Spools are much more stable and secure than flats and easier to lift as well.
I went this route because I don't plan to do a lot of wheel removal and I make it a habit of putting her up on the rear stand every night. It's just nice to see her perk up from behind as I open up the garage door in the morning. bacon
Cider
« Reply #9 on: October 19, 2008, 06:38:03 AM »
I got mine from PitBull, but it wouldn't be hard to make them either.
http://www.pit-bull.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=PBMSA&Product_Code=F0019-000&Category_Code=spool_kits
DrNo08
« Reply #10 on: October 19, 2008, 09:01:45 AM »
Do these fit the 695 perfectly like they do the 696?  They only have these listed for the 696
Ranger06
« Reply #11 on: October 19, 2008, 09:10:18 AM »
I was thinking the same thing, will probably try to call them on Monday.
2008 695 Dark
