January 08, 2025, 09:35:05 AM
anyone put a 180 rear tire on a 696?
Topic: anyone put a 180 rear tire on a 696? (Read 4403 times)
mrplease
October 22, 2008, 09:25:32 PM »
will the 180 rear tire fit on a 696?
i'm looking at a 180/55/17
its only .1" taller than stock (i've seen a few tires that are exactly the same height as the 160 were running) and only .75" wider
and all the tire websites like maxxis, bridgestone etc. says a 180 tires is recommended to fit on a 5.5" rim
i don't see why it wouldn't work...
Last Edit: October 22, 2008, 09:39:52 PM by mrplease
www.cardomain.com/id/mrplease
gearhead
Re: anyone put a 180 rear tire on a 696?
October 23, 2008, 02:34:11 AM »
"work" is the key word here. It will fit surely but as far as working, the cross section/profile won't be correct and will affect the handling in a negative way. If you prefer your bikes look with a wider tire over its handling then a 180 is the way to go.
mrplease
October 23, 2008, 08:08:07 AM »
i found out a 696 has a 4.5" wide rear rim. and that IS to small of a rim for a 180. for some reason i thought the 696 rear rim was 5.5" wide.
guess i'll settle for a 170 which is recommended for a 4.5" rim.
it is basically the same size as the 160 only .4" wider...
NekkedChic
Naked Bikes-u dirty boyz!
November 02, 2008, 06:31:54 AM »
JUST had a conversation about this yesterday with devout track kid.....he kept shaking his head about how "skinny" my rear tire is (stock).....kept saying I should look into at LEAST 180, preferably 190. My SO laughed at this saying WHY? replace with 'fatter", so it's harder to TURN???
Curious tho, what general concensus is on handling and moreso about SLICKNESS? of stock versus going "fatter". I DO hope to do some track days this next year-but for MOST part, run as many errands as possible on bike or weekend twisties rides (hopefully more of latter tho)
LUV to hear thoughts on this, ALL good, bad and ugly and what suggestions for replacements when time comes. Tks
Ducatista Barista
November 02, 2008, 05:18:45 PM »
Your SO is correct, a fatter tire will slow down your handling. All it will add on your 696 is bling factor and maybe a performance gain from the lighter wallet. More powerful bikes need the larger tire for traction.
Last Edit: November 02, 2008, 05:20:30 PM by howie
Ducatista
I don't need to brag about a titanium member.
November 02, 2008, 05:34:55 PM »
Quote from: howie on November 02, 2008, 05:18:45 PM
I've actually wondered how much better my 1999 900s would handle with a 160 rear. My Monster and my SV have exactly the same hp, so it's plainly obvious that I don't need the fatty rear on the Monster. [shrug]
carbon fiber Superbike front fender, bar end mirrors, floating cast iron rotors, carbon fiber chin fairing, Cycle Cat frame sliders, Arrow carbon fiber low mount slip ons, Rizoma billet cam belt covers w/ plexi windows, Rizoma billet front sprocket cover, billet handlebar clamp, carbon fiber rear hugger, tail chop, open air box, Corbin seat, stainless clutch springs w/ black keepers, suicideless sidestand bolt, Evoluzione clutch slave cylinder
www.myspace.com/bitgoddess
