December 27, 2024, 04:17:36 AM *
Author Topic: COMPUTER HELP!!!  (Read 3648 times)
TOB/DMF member since '02
« on: May 10, 2008, 08:17:35 AM »
My Sony Vaio won't start up!!   Huh?
This is the message I get:
Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\ntoskrnl.exe
Please re-install a copy of the the above file
ARGH!!  I have a lot of stuff on that computer!
I am Sofa King
idiot sans savant.
« Reply #1 on: May 10, 2008, 08:26:29 AM »
nail in the hard drive?
« Reply #2 on: May 10, 2008, 08:28:27 AM »
ouch....
Jobu
« Reply #3 on: May 10, 2008, 08:36:22 AM »
Shit.  I had a couple computers with a similar problem.  There is a fix.
make the beast with two backs, it was a little involved.  You have XP on the machine?
Oh yea, I almost forgot.  The requisite answer to a computer question:  Get a mac.
Try this:  http://www.techspot.com/vb/topic74955.html
This is very similar to what I did on the old machines I had and it worked.
« Last Edit: May 10, 2008, 08:39:37 AM by Jobu » Logged
c_rex
Quick! Into the transmogrifier!
« Reply #4 on: May 10, 2008, 09:54:01 AM »
you just need a fresh copy of the file and put it in the folder where it lives.  did they give you a 'recovery' disk?  you may be able to just put that in and walk through the repair process.  this is why I build my own.  proprietary crap can be hard to get through when you need to fix something.
hee hee.. forgot you're 'local'... if you need to borrow a WinXP disk I have about 6 of em around here somewhere.
« Last Edit: May 10, 2008, 09:57:10 AM by c_rex » Logged
prudolph
« Reply #5 on: May 10, 2008, 12:38:17 PM »
well if you have an extra computer, go to radioshack or some other electronics store.Most likely you have a IDE hard drive, pick urself up an external hdd case for a laptop hard drive. (like 10 bucks) Take out ur hdd from the laptop put it into the case u will be able to plug it into another computer via usb just like a jump drive. then you can access it also like a jump drive and copy important stuff to another comp.
Side note. you should wipe out ur hdd and put reinstall about once a year. (windows blows but o well its the truth)
If you have any problems or need a walkthrough on reinstalling pm me. Im also a Computer science major for credibility Grin
GLantern
08 Red 1098, 07 DRZ400S
« Reply #6 on: May 10, 2008, 01:33:51 PM »
Call sony and give them your model # etc they will send you recovery discs specifically for your comp.  run those and there should be a repair option.  Just to be safe though do what drenaline said first by backing up your HDD.
"Just ride and never ever look back"
www.suspectsunlimited.com
Gator
« Reply #7 on: May 10, 2008, 02:01:39 PM »
If you still have your windows disk you can boot up off the disk.
   1.  Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
   2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
   3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
   4. Select the operating system you wish to fix, and then enter the administrator password.
   5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
   6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
   7. Type exit to reboot the computer.
cyrus buelton
aka JuddDDDdd
« Reply #8 on: May 10, 2008, 02:21:42 PM »
+1 on buying the box to slide your hard drive in to.
I had to do that a few years ago, luckily all of my files were still valid.
Buying an external hard drive is a good investment to make a backup of your files; also, storing your files on a DVD/CD is a great way for irreplaceable files (i.e. pictures, documents, etc)
1999 M750 (joint ownership)
2004 S4r (mineeee)
« Reply #9 on: May 10, 2008, 02:28:51 PM »
Thanks guys!
I appreciate the help!!
wt: wt: wt:
