January 09, 2025, 08:07:37 PM *
Pages: [1] 2 3   Go Down
Author Topic: Need some education on Brakes?  (Read 10062 times)
psycledelic
« on: October 24, 2008, 10:44:39 PM »
Ok, I have been thinking about swapping my coffin style brake and clutch assemblies out for the cup style to give me some more options with clip-ons.  My questions are:
Do I have to upgrade everything, or will other types of levers/cylinders work with my current calipers?
What does the (example: 16x18) stand for?
Any advice would be appreciated.
I have the stock Brembo 2 piston calipers and coffin style levers on my S2R800.
06 S2R800 - the wife                         Dolph
04 999s - the mistress
S2R 800 '07
« Reply #1 on: October 25, 2008, 12:09:44 AM »
Grrr...  Evil Oh shit  bang head
Now I have to seriously work to get this idea out my mod infested head. I was planning on getting the Brembo upgrade kit and leave the masters/coffins as they are. However, clip ons have been playing games with me and I do love the look of cool masters and black Rizoma cups.
Well, my dealer told me that any masters will work, but they should be dimensioned just right - otherwise too abrupt or too long travel - the wrong dimension of the cylinder/piston will ruin the power, feel and control. (If I make any sense)
I'm on your team, it will be interesting to hear what the other guys have to say.  waytogo
COWBOY
« Reply #2 on: October 25, 2008, 12:43:03 AM »
I looked into this mod and did it last spring.
I'm running 999 radial masters with upgraded 4 piston 4 pad brembo calipers.
Other options I was given included:
  --  The Ducati brake kit (there used to be one that included upgraded master's along with the calipers lines etc. the price is actually very reasonable.  I only saved 100.00 bucks piecing it all together and buying take offs).
  --  Brembo or Nissin masters new
  --  Finding some used radial Nissin's of a Ninja 1000 (can't remember the years check with Chris at Ca-Cycleworks).
If memory serves the 16x18 has to do with the amount of fluid being forced and impacts the amount of pressure applied and the feedback/feel of the brakes.  Someone with more knowledge will correct/fill that in.
Some things to be aware of
  --  If you're also upgrading the clutch the stock S2R clutch includes in actuator pin that allows you to start the bike in gear while holding the clutch in.
  --  If you go to clip ons you may need to buy a spacer (monserparts.com) so the MC clamps will fit.
  --  If you piece a solution together you'll at minimum have to rearrange/reroute your lines or just replace them all together.
It has turned out to have been a great mod and one I put near the top of the list of upgrades I've done to my S2R.
Good luck.
« Last Edit: October 25, 2008, 12:45:03 AM by COWBOY » Logged
2005 S2R -- Mods installed: DP termi full racing kit, ST4 Forks, S4R rear shock, 999 Radial Brake and Clutch MCs, 4 pot Brembo Calipers, 320mm Snowflake rotors, SBK Quick change carrier, 43T rear sproket, Tomaselli Clip Ons, Cyclecat Frame Sliders, ASV Levers, zero indicators, Supernova taillight
« Reply #3 on: October 25, 2008, 01:53:54 AM »
The first number is the bore of the master cylinder, the second number is the length of the lever pivot.  To maintain the same hydraulic multiplication of force you want the same bore.  Decreasing the bore will increase force, but also increase the lever travel.  Too small a bore and you can run into three problems; too sensitive, too much travel, or a lack of fluid volume to fill the calipers.  Too big a bore; less multiplication of force, less travel.   A shorter the pivot (better leverage ratio) will give you a larger increase in force at the lever.
psycledelic
« Reply #4 on: October 25, 2008, 05:14:56 AM »
Cool, excellent info.  I appreciate the time and help so far.  So I am assuming that as long as I find the same bore x length as my stock equipment, I should be able to swap the controls and keep the calipers(?).   Any idea as to what the stock S2R800 bore x length is.  I looked around on the internet and couldn't come up with anything (I could probably check the manual - just thought of that).
So, if I am processing all of this info correctly, the calipers, and cylinders are specific to the bore x length.  If you want to go outside of that, it would be to upgrade the entire shabang.
You know, for the money I have invested in this bike, I could have had an 848 (in which I would have had enough money invested to own a 1098, in which I would have had enough money invested to own a 1098R......).  It's a never ending cycle.
Again, I appreciate all of the help!
Chchadder
« Reply #5 on: October 25, 2008, 07:12:56 AM »
I just finished a brake upgrade on my 07 695 from the stock coffins to a radial master with piss cup reservoirs this last week.  I too wanted to get a little more room on my clip ons as things were just too tight with the big coffins.  I ended up buying the Nissin kit from Chris at CA and it works just fine.
A couple of things to note:  You will most likely need to replace your lines.  The radial master connection is on the bottom of the unit, necessitating a different fitting angle and a bit more line than the t-harnessed lines allow.  I went with black Spiegler lines and titanium fittings with a Superbike setup (one main off the brake, one over the wheel).  Their fittings can be rotated to fit your specific setup which is a pretty cool feature, though they were positioned just right for me out of the box.
http://spieglerusa.com/
Measure how you want your brake lines to run carefully as most places consider just about any brake line job custom so there are no returns.
I personally recommend investing in a vacuum bleeder (Mityvac, Actron, etc...) because with fresh empty lines (empty of everything but air) you will be pumping for a long time on your own.  A vacuum bleeder will cut the process down to about 20 min a side.  And of course once you have done custom lines on the front its only a matter of time before you want to do the rear, the clutch...  It'll come in handy.
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
« Reply #6 on: October 25, 2008, 08:33:14 AM »
You might try giving Fred at Yoyodyne a call, he handles Brembo stuff and is very knowledgeable.
I'm pretty sure there's folks here that have converted to the 4-piston calipers while keeping the OEM coffin masters.
Can't help you with that.  Grin
BK_856er
2007 M695; 2004 749s
« Reply #7 on: October 25, 2008, 11:43:06 AM »
Look for some tiny embossed numbers on the underside of your master cylinder.  Your S2R800 is probably a 15 or 16mm bore, so one of those numbers should be in the string.  My M695 came with the same brake setup, but I can't quite make out the numbering on the underside.  I measure the pivot-pin distance as 22mm.  Therefore your current master cylinder should be 15(or 16)x22.
For reference, the OE radial setup on the 999 is 18x19 and the aftermarket "GP" brembo radials are mainly 19x18 or 19x20.  Most of the OE non-radial masters for dual 4-piston caliper applications seem to be 15 or 16mm bore - those should work for you and allow you to keep your existing line.
If it's in your budget and you have the need, consider the whole shebang similar to an S2R1000 (rotors/calipers/masters/lines).  Alternatively, you can eke out some additional performance from your current setup with better pads, but those 2-piston floating calipers are somewhat limiting.
BK
2001cromo
« Reply #8 on: October 26, 2008, 04:47:08 PM »
Industrialgrrrl's got 4 pads with coffins. I just had to get custom lines made to make it all fit, since the banjo at the caliper is on the side instead of on top (or is that vice versa?).  And brake tech 320mm stainless rotors.
I've got 999 masters with gold line calipers also with custom brake lines to make it fit. With cast iron 320mm Brembo rotors.
To the OP,
if you've got the 2 piston, 300mm rotor brakes then you will end up swapping at least the rotors/calipers and possibly also the lines and masters.
Also, how do you want the brakes to feel? Hard or soft? a lot of initial bite or progressively stronger? Keep these questions in mind for the parts you choose...
« Last Edit: October 26, 2008, 04:51:16 PM by 2001cromo » Logged
corey
'06 Tang/Black S2R800
« Reply #9 on: October 27, 2008, 11:46:18 AM »
Just a note, i'm 99% positive the kit from ducati DOES include a new master with piss-cup.
squidwood
« Reply #10 on: October 27, 2008, 05:56:21 PM »
s2r 800 4 piston 4 pad calipers with 320mm rotors comes with coffin masters according to picture in DP catalogue.
corey
« Reply #11 on: October 27, 2008, 07:01:45 PM »
From ducati.com:
Golden series braking system kit
Braking system kit, golden series, with 4-piston brake calipers, Ø 320-mm discs and dedicated brake line
Completed with oversized brake master cylinder.
SKU code #96845805B
http://www.ducati.com/shop/product.jsp?catid=cat970133&prodid=prod800122
The picture doesnt show the master, i suppose it could be a larger coffin-style master that is included. but non the less, a master that is sufficient in size to operate the larger brakes is included.
2001cromo
« Reply #12 on: October 27, 2008, 07:58:52 PM »
About brakes
I want to help clear the air here so that everyone who is looking for more information regarding brakes in general and possibly upgrades will have a better understanding of the individual components, what they do and how they interact with one another.  I'm only trying to give everyone as accurate information as possible regarding Ducati's OEM brakes for various models, but mostly Monsters. I'm basing the years on when they first appeared on Monsters, other models got parts at different times. With this info I hope to help others make good decisions with regards to their brakes.
Calipers:
There are a few different types of OEM brake components depending on the year and model of bike.
Any mention of "gold line" this this post means specifically that the calipers have 4 pistons which are 30/34mm in size (yes, they are 2 different size pistons in each side of the caliper) and have only 2 pads per caliper.
There were 2 different types of "gold lines" throughout the years.  They are generally referred to as "single pin" or "double pin" and those pins are used to hold the brake pads in place. These calipers are designed to work with 320mm rotors.
From 1993 - 1999 Monsters, SS's & 851/888's used "single pin" gold lines that had 40mm spacing between the mounts that held them to the forks. The smaller bikes (600's & 750's) generally only used one caliper on the left side.  There is some mention a few years back from Chris Kelly that the original “single pin” calipers had a little more flex to them then the newer “dual pin” calipers.
The pic below is a "single pin" gold line.
From 2000 - 2007 "most" Monsters, SS's and ST's used "dual pin" gold lines which had 65mm spacing between the mounts that held them on the forks. Functionally these are identical to the "single pins". Again some smaller models used only one caliper on the left side.
The pic below is a "dual pin" gold line.
In 2006 to current some Monsters used the black 2 piston calipers which are also used on the Classic series bikes with the spoked wheels. These calipers have only 2 pistons on one side. These calipers are designed to work with 300mm rotors. They still use the same 65mm fork mount calipers as other similar year Ducati's (either the gold line "dual pin" or the 4 pads are the same 65mm).
See pic below for what these look like
In 2007 when the S4RS first came out it used "radial mounted" calipers. Also the 749R/999R had these as well. This refers to how the caliper(s) attach to the fork legs. Basically the bolts which hold the caliper to the fork lowers are perpendicular to the front wheel axle.  I don't have the pistons size(s) for these.  All of these "radial mounts" use 4 individual pads per caliper. there's probably a model that doesn't, but most are 4 pads
"4 pads" These calipers were used on some of the 749/999 & 748R/996R/998R bikes and sometimes found their way onto the front of other Ducs. These are the only "axially mounted" calipers which use 4 individual pads per cylinder and they are not "gold lines". They are always called "4 pads" and they come in either silver or gold. They are easily distinguished by the bridge that goes over the top center of them connecting each side of the caliper. Note: people often confuse these with "gold lines" or vice versa. They are very different calipers. These have 34/34mm pistons and more initial bite to them. Because of the larger leading piston and twice as many leading brake pad edges as a "gold line".
See pic below for a "4 pad"
Master Cylinders
Again there are a few different types that Ducati has used over the past 15 years.
1993 - current There have been both coffin style and gold line aka "pee cups" or "remote resivours". For the most part they are BOTH 16mm pistons as long as it's for dual calipers. There were a few 15mm's but I highly doubt you're going to trip over them these days. I'm not sure what the 300mm 2 pistons use, but I'm betting it's either 15 or 16 and most likely 16mm. The only difference between the pee cups and the coffins is look and clearance to the surrounding area. They also use different levers which are not interchangeable. <-- One exception here, the first generation of remote style's used the same large bolt for the lever and you could swap levers between coffins and remotes. But those stopped being produced about 1997/8 when they went to the now used smaller bolt on the remotes. The coffins always have/had the larger bolt holding the lever to the master and since 1998/1999 the remotes have had the smaller bolt.
For the single caliper front brakes (I believe) Ducati used either a 13mm piston as it was only pushing half as many brake pads. If you plan to switch either way, keep this in mind as it will drastically effect the feel/power of your most valuable brake.
Pics of each below
Coffin
Remote
Ducati also uses Radial master cylinders on the latest Monster S4RS and S4R-2008. The advantage to radial master cylinders is improved power/feel. But in all honesty you don't get much of either with these. Don't get me wrong they're still great brakes! But if you want more spend the extra $$ and get the racing radials from Brembo for the best of both power and feel.
Pic below of what's on the S4RS
The 749/999's also use radial masters. They have 18mm pistons and a banjo bleeder inside the resivours which can be handy for getting the last little bit of air out of the system.
Rotors
There are 2 types of rotors that Ducati has used in most models.
They are "semi floating" and "full floating". Please realize, "semi floating" is closer to fixed than full floating.
What this is referring to is the way the actual brake rotor blade (the outer most part where the pads grab) stays fixed or "floats" where it's connected to the rotor's carrier/center by the buttons.
Like everything else on a bike, the main goal here is to have incredible performance that doesn't weigh very much and maybe even last a while.
This weight is especially noticeable because it's added to that gyroscope we call the front wheel.
The main reasons for different materials for the blade and the carrier and the different ways of attaching these 2 components together is because they get VERY hot and can warp. Also because if the rotor is "floating" it can move with very little or no resistance by the brake pads as they usually pretty close to one another.
Semi floating rotors are far more common these days and also less expensive to produce.
The most common material for the blade is stainless steel. It allows use of wider variety of brake pads, it doesn't rust very easily and is less expensive to produce. Other materials used for the blades are "Iron", "Carbon" and "Carbon Matrix Composites aka CMC's".
Iron blades have been used in racing for years as they provide excellent power/feel. The only drawbacks are that it's slightly heavier and have a limited amount of brake pad choices (organic only).
Carbon blades are very light and ONLY used in racing, because they do not work well until they have built up heat in them. But when they're hot, they're incredibly powerfull! Not to mention they take many months to produce and are VERY expensive and have limted choices in terms of brake pads.
Carbon Matrix Composite rotors have only been developed in the past few years. They have the lightness and power of Carbon rotors, but they have been developed so that they work well all the time. They are also very light and take far less time to produce.
The image below shows Cookie cutter rotors common on all Monsters from 1993-1999. They had steel carriers and stainless "semi floating" rotors.
The image below shows "Snow flake" rotors common on most Monsters from 2000 - 2006. They had aluminum carriers and stainless "semi floating" rotors.
The image below is "Full Floating" rotors which were only on the 2000 S model Monster as well as a few other Ducati's
The image below is a "Full Floating" CMC rotor.
Important size/notes about the rotors. They are mostly all 320mm in diameter and have 6 bolts holding them to the front wheel. The only exceptions are the newer Monsters that have the 2 pad calipers as they have 300mm rotors, but the same 6 bolt pattern to the front hub. Also the S4RS and 2008 S4R have a 5 bolt pattern holding a 320mm rotor to the front hub.
All SS's and ST's have 320mm with 6 bolt. All 749/999 have 320's with 5 bolts holding to front hub and a different offset. The only odd balls in this are some of the 748R/996R/998R and 749R/999R as they have a different offset, have 6 mounting bolts and require special 320mm discs.
Brake Pads
This is the cheapest and easiest way to improve the performance of your bikes brakes. There are many choices here and I"m not going into each one. I will only say that you need to listen to what others have to say and test/try yourself. Good brake pads combined with a freshly changed good brake fluid and stainless brake lines can do wonders to improve the performance of your brakes. Most high performance brake pads are "sintered" which means they have metal bits in them to increase the stopping power.
Brake lines
Stock brake lines on some bikes are often rubber, this deteriorates over time and also expands under hard use. Both of which are not good for either feel or performance. Best solution is to use stainless lines as they don't deteriorate and they don't expand. Just make sure the stainless lines have a coating over them (most do these days) or they work like saws on anything they rub against. Thankfully for us, Ducati uses stainless lines on most all models for the past 10 years at least. So we've got brake lines covered from the factory  Wink
A few last words here
Keep in mind the old Pirelli add "Power is nothing without control" when considering what you want your brakes to do.
Also ask your self "how do you want them to feel, either hard or soft and should they grab the same all the time or get progressibly stronger?
The choice is yours and you can combine many things to achieve what ever you want.
A few good links:
http://www.oppracing.com/pages/articles_brembo_master_cylinders/
http://www.braketech.com/tech_talk.php
http://www.yoyodyneti.com/Product/brembo_brakes.htm
http://www.ducatitech.com/2v/aftermarket/brakes.html
« Last Edit: October 30, 2008, 06:41:42 AM by 2001cromo » Logged
ghosthound
« Reply #13 on: October 27, 2008, 08:04:21 PM »
From ducati.com:
SKU code #96845805B
how much does this kit run?
« Last Edit: October 28, 2008, 06:49:50 AM by ghosthound » Logged
corey
« Reply #14 on: October 28, 2008, 04:18:11 AM »
Dont have an exact number for ya, but from what i recall hearing, around $860 bucks. It's pretty competitively priced. You would spend very close to that trying to piece something together from what i understand.
Pages: [1] 2 3   Go Up
