whats the dif?
Started by whits, October 27, 2008, 04:45:23 PM
whits
What is the difference between 06,07,08  monster sr2  1000's? Just paint?
Duc Fever
Well I know '07 is when the 50% less service costs started being touted ;D
"You have not converted a man because you have silenced him" ~ John Morely
Statler
Hello and welcome to the DMF.   Some tech savy folks will be along in a minute (I believe Brad Black has commented on some differences between 06 and 07 one thousand motors).
In the meantime, it's polite to start here:      Introduce Yourself
Well, there is no '08 S2R1000, there are M1100 and M1100S, though.
scduc
Speeddog---I think you miss typed, Cu I own an 08' S2R 1k
PizzaMonster
Quote from: Speeddog on October 27, 2008, 05:56:25 PM
Speeddog...I've been accused of being stuck in a time warp before so I could be wrong but isn't the M1100 a new for '09 model?  I thought the S2R1000 was still offered this past summer but the 800 was cancelled.
Not that I know anything about it for sure but didn't the pre- '07 S2R1000's get away without the closed-loop emission system hence they don't suffer from the intermittent surging and high idle problems of the newer bikes?
The Ducati Monster Forum - Time Well Wasted  :-)
Quote from: scduc on October 27, 2008, 06:11:18 PM
Duh...I'm slipping... I just worked on one.
That's what I get for looking at ducati.com.  [bang]
Yeah, '08 S2R1000 is listed as far as the parts catalogues are concerned, but doesn't show in the '08 Monster page. Weird. or not.  :P
'06 S2R1k is a closed-loop bike.
 No one loves the big 2v anymore!!!!!
The S2R1k is brand new for 2006, and has an O2 Sensor.
Technically speakinig there is a difference ECU wise between the 06 and 07/08 models (assuming 07 and 08 are the same). What the exact difference is, i cant tell you, but what i can tell you is, the Rapid Bike Unit that works for the 06 model will not work for 07+. The 06 RB O2 emulator will work for 06, but not 07+. when you unplug the O2 sensor, the light does not go on the 06 (however for a particular member, his check engine light did go on, i think he might have an 07 ecu), for the 07+ models they go on.
Any other differences im not aware of. Someone else can chime in.
corey
no o2 sensor on the '06 s2r800 either
