January 07, 2025, 03:50:12 AM *
News: Please Help
Author Topic: m900 parts manual?  (Read 5192 times)
erkishhorde
« on: October 28, 2008, 05:34:33 PM »
I checked the Ducati site and I can't find a parts manual for the old m900. Can anyone point me to one? If not, what would be the closest comparison to the new(er) monsters? Maybe the 695?
« Reply #1 on: October 28, 2008, 05:49:11 PM »
The 2000 catalog will be as close as you'll get from ducati.com.
Might try duc.nu
erkishhorde
« Reply #2 on: October 28, 2008, 06:06:53 PM »
In 2000 they were FI, though, right?
« Reply #3 on: October 28, 2008, 06:09:48 PM »
correct.
The FI bikes also had tranny and primary gear differences.
you might find a dealer that is no longer using fiche for parts lookup and buy the micro-fiche.
Did you check duc.nu?
erkishhorde
« Reply #4 on: October 28, 2008, 06:10:51 PM »
Yup, they don't have parts manuals for any of the monsters. Odd.... Roll Eyes
greenmonster
« Reply #5 on: October 29, 2008, 08:50:43 AM »
I have a PM f 91-97 900SS if it helps.
PM mail if so.
M900 -97
MTS 1100s  -07
lemond
« Reply #6 on: October 29, 2008, 05:33:33 PM »
greenmonster, can u please pm me the manual too? thanks!
2000 GSX-R 600 Track Bike
1995 Ducati Monster M900
greenmonster
« Reply #7 on: October 30, 2008, 02:21:27 AM »
Done, erkishhorde & lemond.
M900 -97
MTS 1100s  -07
krista
... does she have a
ducati addict
« Reply #8 on: November 04, 2008, 01:08:57 AM »
2000 M750 has all the same carb'd parts as older M900s. Only difference will be the 3 phase vs 1 phase charging system. Use the 900ie for anything you can and the 750 for the carby and electrical stuff.
Smiley
erkishhorde
« Reply #9 on: November 04, 2008, 03:52:59 PM »
Good to know. Thanks for the info, Chris!
clubhousemotorsports
« Reply #10 on: November 04, 2008, 06:16:24 PM »
Be careful with the 750 to 900 carburetor cross overs as there are differences.
the bodies have different pressed in air jets, needle jets are a different size as are mains and some times pilots.
Slides I think are the same as most o-rings and seals.
Also with the different charging systems come different crankshafts and the gears that run off of them (timing gears).
If you look around you can find manuals for older supersports for cheap $$$ on the net. the motors were mostly the same. the SS never had small valve heads. this will mean different valves and cylinder heads as well.
good luck
