Is this a fuel line?
Started by yellowjacket, May 10, 2008, 11:52:23 AM
yellowjacket
I looked under my bike and noticed this tube hang-out, is this normal? or is it suppose to be attached to something?
03 M800S IE- my first ever bike.
Dunno if there's supposed to be a photo - But it's probably not your fuel line.  IF it was your bike would be dumping a lot of gas any time the fuel pump was active.  It's probably the tank breather hose or the battery overflow hose.  Both will be snaking down from under the tank, down past the lowest point of the bike and will be left open at the end.
yellowjacket
yeah i did attach a pic, but that sounds about right (and better!), thanks
Rameses
How big is the line?
Fuel lines are roughly 5/8" O.D. while the vent lines are maybe 1/4" iirc.  Maybe somebody else can confirm this?
But like yuu said, if it's a fuel line, when you turn the bike on you'll know it.
lawbreaker
Quote from: yellowjacket on May 10, 2008, 11:52:23 AM
yes its normal... its an overflow hose
c_rex
Does the bike run without fuel spilling all over the place?  if so I think you're good to go.   [thumbsup]
yellowjacket
#6
yeah, its definitely not the fuel line...
clubhousemotorsports
that should be the fuel tank overflow and drain line.
open your fuel cap and blow up through the line , air should come out the drain and vent if t'd together.
if the vent line becomes pinched the tank can implode
if the drain becomes plugged water can get in you fuel tank.
cheers
