ooh I'm getting a horn
Started by brimo, October 29, 2008, 09:43:58 PM
brimo
The frightener on the monster is a bit lame so I'm thinking of installing the Stebel compact Nautilus,
http://www.stebel.it/stebel/index2006.htm
Can get one of these for under 50 bucks and it will fit where I want to put it.
Anyone tried anything else?
From a story by RAT900
loony888
fiamm made something similar a few years back with two small trumpets mounted directly to the compressor, the stebel looks a little more discreet though, and $50 sounds reasonable.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
ptooey
p2e.
:p~
Betty
Some proper horns for the Lammie perhaps  ;D
Spider
Quote from: ptooey on October 30, 2008, 12:24:46 AM
very thorough review and brand comparison here:
http://www.webbikeworld.com/motorcycle-horns/motorcycle-horn-comparison.htm
JC, a horn could keep those women from backing into you...that is the weirdest avatar since Dos's cloud pornography. You one messed up kid!
ptooey
Quote from: Spider on October 30, 2008, 03:34:21 AM
ahh the avatar-- lemme put things into perspective for you spider, was some chuckle-worthy scenery i sighted whilst on my travels on the interweb:
p2e.
:p~
brimo
Women like to back in to me too, must be the way I use my horn.......
CairnsDuc
I'm thinking about getting a trailer for the Ducati......
Jukie
maybe i should put that on lillie, but i think she wouldn't be able to move
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
BribieDuc
Hi Brimo,
I'm running with the Monster with the Stebel compact Nautilus.
Been there for a few years. brought off ebay for about $45 I think.
Mounted in same location as original horn with a simple alum bracket which I made.
Relay that came with it is mounted under the seat.
Bloody loud and has helped me be noticed a few times now.  [cheeky]
Only issue is when the bike is serviced, as it affects the disgnostic readings - so install with quick release connections so it's easy to dis-engage for servicing.
Can post a pic or two if it helps.
John
brimo
Quote from: BribieDuc on October 30, 2008, 08:06:31 PM
Hi Brimo,
John
Have decided to go with the compact nautilus after a bit more research.
Thanks, a pic won't be necessary, should be able to fabricate a bracket with no problems.
Also Thanks for the heads up on the servicing diagnostics, wonder why that is so?
It's only a relay in the horn circuit after all.
Two dogs
Hi Brimo,
Hi , just purchased one as well would like to see a photo of the bracket you made and also the relay under the seat if possible , also with diagnostic does the relay affect also?
Did you rig it up so the horn works only when the bike is running?
cheers
dez
John
dragonworld.
brimo
Have not mounted it yet, but should be this weekend, as soon as i do I'll post a pic or two
Andrew
dragonworld.
Hmmmmm, "Mounted" ??  ;D
"Horn" ??  ;D  [cheeky]
Heheheh!!  ;)
