power commander compatibility?
Started by rkundrat, October 30, 2008, 05:32:47 AM
rkundrat
So are the power commanders for the 620, 800 and 1000 all the same? I know they have different part numbers, and one can load whatever map they want, but physically, connectors, wire lengths, etc. is that all the same? thanks!!
Italians have it pretty figured out...
2003 Monster 800s i.e.
Remus high-mounts • PCIII • Evoluzione slave cylinder • Tommaselli clip-ons • CRG & Pazzo levers • Sargent seat • CRG bar end mirrors
1992 Alfa Romeo 164S
Quote from: rkundrat on October 30, 2008, 05:32:47 AM
Basically. The 4vs have a different wire harness. That harness can be made to work on a 2V. It looks like it plugs right in, but I'm pretty sure it doesn't. The 2Vpciii has a wire tap for the tps. For the 4V it has a plug.
The differences in each 2V model is positioning. One may be deisnged to be placed at location x or y, and thus will result in a different length of wire
rkundrat
Ok, I'm primarily talking the 2v, 02-04 620i.e., 800i.e. and 1000i.e. (no 2r versions.) Of those, the connectors should be the same, just a possibility of different wire length based on control unit location? thanks.
2001cromo
The 2v 620/750/800/900 will all work the same as they're all based on the same small block 2 plug design which uses a 5.9 ECU.
I don't know about the 1000, so I'd just go with the above.
Regardless you will need a custom map and will NOT be able to load a map from another engine size bike into a different engine size PC3. <-- Hence the custom map. If you choose do to this, just leave a zero map in it until you have someone with the ability to make you a proper map.
What I've stated is not hypothetical or untested. For the record, I have done this and used a 2v 800 PC3 and installed it into a 2v 620 and then swapped in a 900 engine and used the same PC3.
Quote from: 2001cromo on October 30, 2008, 11:43:13 AM
That is strange, when i was toying around with a PCIII i had (for 05 S4R) i could load 2v maps on it....
