April 29, 2024, 12:16:47 AM
Speedo misaligned Fix??
Topic: Speedo misaligned Fix?? (Read 4132 times)
vt duc
May 10, 2008, 11:38:14 AM »
Hi All,
I just noticed that the speedo on my 2006 S4R was reading "high" by almost 8+ MPH thru the whole range. Then I noticed that at "rest" it reads 8 MPH @ a dead stop. Which is to say it doesn't seem to return to rest at 0 like it should. Has anyone experienced this and is there a reasonable fix to readjust the gauge needle?
Thanks
Dan
2006 S4R Monster- Full Termi setup, CRG levers, MPL pressure plate and cover, T-Rex sliders, Ohlins side damper, DP CF front fender, belly pan, side covers, rear hugger
Garage Mates: 91 BMW K75s, 95 BMW R1100R, 94 BMW R1100RS, 1957 BMW R69 "The Classic"
Zaster
Only Pam can touch my
2007 S4RS (sold) , 2008 1098S (sold), 2013 1199R,
Re: Speedo misaligned Fix??
May 10, 2008, 12:46:44 PM »
My wife just read the subject and thought it might be about
a swimsuit mishap
ScottRNelson
Mr. Dual Sport Rider
May 10, 2008, 01:04:50 PM »
You should feel lucky that it's only 8 mph. The speedometer on my 888 is off a full 20%. If it says I'm doing 100, I'm really doing 80.
The only thing I know of is to send it somewhere like Palo Alto Speedometer and have them calibrate it.
vt duc
May 10, 2008, 03:06:34 PM »
This may be a stupid Question. But are the spedo housings "sealed"?? I thought I could open it up and manually adjust it.
AndrewNS
May 10, 2008, 04:00:36 PM »
Mine is also wildly optimistic. Does anyone know if the tach is accurate? If so, you could probably work out a correction factor pretty easily.
Last Edit: May 10, 2008, 04:03:02 PM by AndrewNS
ScottRNelson
May 10, 2008, 04:50:20 PM »
Quote from: vt duc on May 10, 2008, 03:06:34 PM
The only way to get inside is to cut the plastic.
