September 04, 2024, 10:22:51 AM
Please Help
LED's / Gauge work
Topic: LED's / Gauge work (Read 12115 times)
Heath
LED's / Gauge work
October 31, 2008, 01:31:02 PM »
It's raining
I'm bored
Enjoy
half way done
imobilizer
I never was a big fan of orange
Last Edit: November 01, 2008, 12:35:11 AM by Heath
2007 Ducati Monster S4RT
Re: TEASE: Gauge work
October 31, 2008, 01:37:17 PM »
Ooooooo...
Zexy!
DucSteve
Hey Yo
October 31, 2008, 02:41:35 PM »
So speedo is going to look blue?
Heath
October 31, 2008, 02:56:01 PM »
Quote from: DucSteve on October 31, 2008, 02:41:35 PM
I went with white. The lighting is bad in my garage. I wanted to do blue but nothing is really blue on my bike so I figured white was safe.
mmakay
695
October 31, 2008, 03:11:40 PM »
Are the LEDs surface mount, 3mm, 5mm, or
- Mickey
Heath
October 31, 2008, 05:55:15 PM »
Quote from: mmakay on October 31, 2008, 03:11:40 PM
PLCC2 SMD / SMT LED
bought them here
LED Mod
Here is a IZ style picture. I will bust out the tripod later. When I get sometime I am going to write up a rough tutorial.
Anyone remember how to adjust brightness? I have no clue what mine is actually set at right now.
edit: turn bike on > press button B to adjust
Last Edit: October 31, 2008, 06:15:20 PM by Heath
Munch
Monster S4R - Munchstrada 1100S - 749R
October 31, 2008, 06:18:56 PM »
How did you split your gauges?
mmakay
695
October 31, 2008, 06:20:52 PM »
Ooooh ... itsy bitsy surface mounts. Not sure my soldering hands are that steady. Looks good, though!
- Mickey
Heath
October 31, 2008, 06:29:38 PM »
Quote from: Munch on October 31, 2008, 06:18:56 PM
There are a series of screws you have to undo. 3 in the back then 1 in the front. The front one is revealed when you remove the plastic piece that is between the gauges.
Quote from: mmakay on October 31, 2008, 06:20:52 PM
Yeah I had to stop in the middle of it to resteady myself.
Munch
October 31, 2008, 07:06:13 PM »
Having split yours, think it's possible to get the clear plastic out, and replace with glass?
October 31, 2008, 11:15:11 PM »
Quote from: Munch on October 31, 2008, 07:06:13 PM
its defintely possible. But why?
Id love to do this mod, but how much would a soldering iron that can do a job that precise cost?
maybe you can be a mini sponsor!
Beyote
Re: LED's / Gauge work
November 01, 2008, 06:10:18 AM »
Very Nice.
Capo
You Are What You Is
November 01, 2008, 06:36:47 AM »
Quote from: He Man on October 31, 2008, 11:15:11 PM
It is very difficult to get the plastic out as it is 'fused' into the case. I haven't heard of anyone doing this successfully
Why? to replace a cracked glass, otherwise you have to buy a complete cluster.
Last Edit: November 01, 2008, 06:41:52 AM by Capo
Capo de tuti capi
Munch
November 01, 2008, 06:49:50 AM »
I've got some light scratches on the outside, that I'd like to eliminate by replacing with glass.
Tried the usual scratch removers to no avail...
accrocker
Reply #14 on:
January 01, 2009, 05:34:00 PM »
How were you able to remove the speedo and tach needles from the motors to completely remove the circuitry? I tried to separate them, and they seem to be permanently mounted to the drive shafts off the motors.
07 monster 695, tail chop, custom flashed dp ecu (no more immobilizer!!) high mount marving megaphones, pod filters and an Acewell 4000 gauge set
