January 10, 2025, 08:55:10 AM
Please Help
DS1000 Valve Adjustment
Topic: DS1000 Valve Adjustment (Read 4082 times)
Ivan
Turn 3 at Streets of Willow
October 31, 2008, 05:55:28 PM »
I checked my clearances, and found that a couple of the closers were loose, but the openers are still around .004. Removed one of the closer shims, measured it, and got a replacement from the dealer that should get the clearance close to .001 (I did measure the replacement). When I reassemble everything, I'm finding that the opener rocker arm won't slide back into place. It appears that I now have negative clearance for the opener, yet I'm using the same opener shim that I removed. I'm sure that the cam is positioned such that the rocker can slide over, because it will slide if I remove the opener shim. Can this happen if the closer shim that I installed is too large?
Sold: 2007 S2R1000 for canyon carving and commuting - DP ECU, PCIII, BMC air filter with open box, Zard full exhaust, Race-tech fork internals, Ohlins steering damper, and a Penske 8987 triple clicker
2000 996XU (extra ugly) for track days - BST carbon wheels, Ohlins shock, reworked fork, FBF exhaust, and a bunch of megacycle rocker arms. The rest of it is junk - Hey, I'm just happy that it runs...
Sold: 2002 Aprilia RST1000 for touring - De-restricted airbox, Taylormade Racing exhaust
Re: DS1000 Valve Adjustment
October 31, 2008, 06:11:25 PM »
Sometimes it's a bit of a struggle to get the opener rocker back in position.
Rotate the cam back and forth a bit as you try to slide the rocker over.
October 31, 2008, 06:12:50 PM »
Quote from: Speeddog on October 31, 2008, 06:11:25 PM
+1...
and make sure the engine is still at TDC
Ivan
October 31, 2008, 06:37:41 PM »
Quote from: ducpainter on October 31, 2008, 06:12:50 PM
+1...
Thanks guys. Its still at TDC, the crank has not been turned since I started. I know what you mean about there being a very small window in which the rocker will actually slide into place, I got a good sense of this by sliding it over without the shim in-place. I gently roate the cam to fnd that window as I slide the rocker, but it just won't go with the shim installed. I'l keep trying....
I take it that there is no way having too large of a closer shim could cause this? I don't see how it could, but I'm at a loss since that is the only thing I've changed.
October 31, 2008, 07:16:13 PM »
Closer shim shouldn't have any effect.
You've got the belts off, right?
billg69gmc
October 31, 2008, 07:45:07 PM »
Quote from: Ivan on October 31, 2008, 06:37:41 PM
This may help... If you remove the closer to give yourself temporary space to slide the rocker over. This will let you find the magic spot to where it will slide over. If you are off just a bit, I have found you could still can snap the rocker lose for removal, but going back is not going to happen until you get it in the proper TDC position.
I'm trying to recall that with one valve (cant remember if it was intake or exhaust), you had to actually press down on it with the same method to remove the collets, in order to allow for enough clearance to slide the rocker over. I believe it was the exhaust... but dont quote me on that!
2010 StreetFighter S 2008 Hym1100 2006 S2R1k
Ivan
October 31, 2008, 08:04:54 PM »
Quote from: Speeddog on October 31, 2008, 07:16:13 PM
Yea, belts are off.
I've followed the descriptions In LT Snyder's book, and the video on Cal Cycleworks. I'm finding that this is nothing like the video. In the video, the cam can rotate 360* with both rocker arms slid over, but I'm finding that I can only slide one or the other over, and the cam can't rotate that far because the closer rocker interferes with the opener rocker. For example, once I rotate the cam enough to get the intake rocker slid over, there is no way to rotate the cam again to find the sweet spot that will let me slide the exhaust rocker over. In order to slide the exhaust rocker over, I need to move the opener rocker back into its normal position. I assume this is normal with the DS1000, or have I somehow managed to really mess things up?
Ivan
October 31, 2008, 08:28:51 PM »
Quote from: billg69gmc on October 31, 2008, 07:45:07 PM
You mean removing the opener shim, right? If so, I've done that.... that is why I think it should be sliding over.
brad black
October 31, 2008, 09:18:46 PM »
the 1000 are real pita to do this on. we remove the rocker pins - it's just easier. i think it is a case of can get it off, but not back from memory.
just don't damage the make the beast with two backsing o-ring on the rocker pin cover.
Brad The Bike Boy
http://www.bikeboy.org
October 31, 2008, 09:36:37 PM »
Addendum to my first post:
You can push down on the opener shim (fighting against the closer spring) with the same hand that's trying to slide the rocker over, while your other hand rotates the cam back and forth a bit.
brad black
November 01, 2008, 04:44:13 AM »
Quote from: Speeddog on October 31, 2008, 09:36:37 PM
what he said. and he means fight.
Brad The Bike Boy
Ivan
November 01, 2008, 06:29:59 AM »
OK. I'll give this a try when I get back out to the garage. This had crossed my mind, but I don't understand why it should be necessary. There was a .004 gap between the opener rocker and shim when I started, and the rocker slid out of the way easily.
Quote from: Brad Black
I noticed that.....
yes, the rocker moved out of the way easily enough, but getting it back home is a different story. If Speeddog's method doesn't work for me, I'll study the section in the factory manual on removing the rocker pins.
Thanks all....
November 01, 2008, 07:15:52 AM »
Quote from: Ivan on November 01, 2008, 06:29:59 AM
--------------snip--------------------
The cam position where you can slide the opener rocker over actually has the valve open a little bit, so there's some closer spring pressure involved.
It's a lot easier to drop your keys than it is to pick 'em up.
Ivan
November 01, 2008, 10:14:32 AM »
OK, the problem is that I am an idiot. The keepers were not fully seated, so the closer shim was causing the closer rocker to bind on the cam shaft. You need to really snap that closer rocker to seat the collets. Yes, it shows this in the video, and I thought I was doing it right, but I just wasn't snapping it hard enough.
On to the next valve....
uclabiker06
"The time you enjoy wasting isn't wasted"
Reply #14 on:
November 01, 2008, 01:00:57 PM »
2006 S2R
2009 Smart
