triple clamp removal
Started by REDUC, November 02, 2008, 02:16:41 PM
REDUC
So, how do you guys support the front of the bike when you remove the triple clamps?
Howley
A jack and a block of wood under the front cylinder, and a rear stand.
Quote from: Howley on November 02, 2008, 03:20:53 PM
Right on the head?
I generally put a jack on the headers. but i guess its the same thing.
Jobu
If you have any exposed beams and ceiling joist in your garage/workshop, then use ratchet straps around the front of the frame.  That's by far the safest method.
Other than that, you'll have to use a jack.
Howley
Quote from: He Man on November 02, 2008, 04:56:59 PM
Right on the head?
More like the barrel.
m9hundo
use a ladder and some tie downs (ratchet type). Roll the front end right underneath. Safe and sound
whats moepery? moepery is when you expose yourself to a blind person.
uclabiker06
Get a come along and wrap it around the roof beam then attach some tie down straps to the frame and once you get it off the ground put a jack or two underneath it just for insurance.  Of course this method assumes you have a rear stand.
2006 S2R
2009 Smart
DucHead
Quote from: Jobu on November 02, 2008, 05:25:15 PM
+1 on the support from above.
