November 23, 2024, 11:00:23 AM *
Author Topic: road paint got me...it got me good  (Read 1395 times)
VTP
« on: November 04, 2008, 09:09:03 AM »
Hey guys i havent posted much but ive been trolling for a while now. coffee
I hit a patch of wet road paint and it splattered all over the motor...BUMMER. bang head
SO, i was wondering if anyone here had any suggestions on who can get it all off, I have had limited experience with Sideways Salon, but if anyone had any more local suggestions i  would love to hear about them.
I live in Austin.  Thanks again.
Porsche Monkey
JuddDdd likes my
The DMFer formerly known as Ducaholic
« Reply #1 on: November 05, 2008, 05:00:46 AM »
Thats a good one.  Everybody here seems to like simple green but I don't know how it would handle road paint.  You want to be careful so you don't damage the bikes finish.  You can try some carb cleaner too but be carefull.
spaceghost65
Lento come un inferno e non può girare
« Reply #2 on: November 05, 2008, 07:48:21 AM »
Road paint is a latex so it doens't stick well to enamel surfaces but adheres very well to pourus surface (like motors). I would try getting a small plastic scraper (not metal) pick a spot and see if it will peel up and away from the part without any chemicals first. if it does you then can get a scotch brite pad (NOT steel wool) and use some softscrub and work the area.
if it doesn't lift way consider using a spray bottle of simple green/water with a dremel with a polishing head mounted at a low rpm. spray the solution on a test area and touch the polisher to the surface to try and break it up , then try again with your scotch brite pad. The key is to avid marking the metal surface in any way.
anything that's not metal use a soft plastic scraper or your fingernails. go easy on everything especially any painted areas.
MurDuc
2003 M1000S
« Reply #3 on: November 05, 2008, 09:48:08 AM »
Take with a large grain of salt.
I had road construction on the only road leaving my neighborhood for the whole summer when I first got my Duc.  Tongue
I had some good luck with simple green on some things. But I had to go to a Bug & Tar remover for some others. I was very careful with it, but it did the trick without damage or blemish.
Try a small amount in a very inconspicuous area first, of course, I am by no means an authority on such matters.
   Master of Suds / LSD - Department of Hooliganism
VTP
« Reply #4 on: November 05, 2008, 09:57:28 AM »
right...i have both of those products, simple green and the tar/bug remover but quite frankly i dont have the time.
so i was thinking of just taking it to a detail shop and saying "have fun".
i dont have the patience or enough q-tips to get my bike clean like i want it regardless so i hope that this works.  thanks guys, let me know if you hear of any shops around austin who would do a good job.
-VTP
edit:  oh and thanks again for the recommendations.
« Last Edit: November 05, 2008, 10:06:19 AM by VTP » Logged
