January 08, 2025, 04:06:19 AM *
Author Topic: Installing Goodridge 2 line brake kit on 95 M900  (Read 1772 times)
lemond
« on: November 04, 2008, 12:49:48 PM »
I just got a Goodridge (DU2801 - 2FP) front brake line kit for my '95 M900 and I have no idea how to install this. My M900 have dual calipers on the front and the two brake lines hooks into a junction box (behind the headlight), the junction box is controlled by a cable into the master cylinder. I googled the Goodridge kit and it said  "2-line race kits. Dual front lines run directly from the master cylinder to the calipers thus eliminating the junction block." so how do I run the two lines from the master cylinder???
2000 GSX-R 600 Track Bike
1995 Ducati Monster M900
krista
... does she have a
ducati addict
« Reply #1 on: November 04, 2008, 01:20:06 PM »
You use a double banjo bolt on the master cylinder and then route the lines to each caliper (any way that they will work). You are replacing the entirety of the stock setup.
« Reply #2 on: November 04, 2008, 01:26:10 PM »
^^^  What he said. The lines coming out of your master cylinder should look something like this:
...and then you simply run one line to each of your calipers.
knightrider
« Reply #3 on: November 04, 2008, 05:16:24 PM »
you would think they would have supplied said double banjo.  galfer includes new banjos and crush washers. bummer
1994 M900
clubhousemotorsports
« Reply #4 on: November 04, 2008, 05:52:23 PM »
Do your self a favor and buy a double banjo bolt that has a bleed screw in the end of it if you do not already have a bleed screw on your master cylinder.
Pay  close attention to the fittings to make sure there are no leaks of brake fluid when you are done.
good luck
