January 30, 2025, 10:11:30 AM
SoCal Monsters
Brake Bleeding help and other silly questions!
Topic: Brake Bleeding help and other silly questions! (Read 3479 times)
GregP
November 13, 2008, 07:22:16 AM »
I have only bleed the brake system on my CRF and being it is a single caliper it was a snap.
I just swapped out the brakes on my SV and there are two calipers and I'm confused.
Do I have to bleed both calipers at once or can I do them one at a time? I've been working the one at a time and have not been able to get the suckers to full power.
Any suggestions, hints or directives?
Also, anyone within a 5 minute walk from my house have one of those brake vaccum thingies?
Thanks
Last Edit: November 13, 2008, 03:22:01 PM by GregP
Don't expect much and you won't be disappointed.
erkishhorde
Re: Break Bleeding help and other silly questions!
November 13, 2008, 08:00:35 AM »
I've only bled my front brake lines once but I don't remember doing both at the same time.
derby
Re: Brake Bleeding help and other silly questions!
November 13, 2008, 04:05:20 PM »
from the top to the bottom...
bleed the master first, then one caliper, then the other caliper.
-- derby
'07 Suz GSX-R750
click
here
for info about my avatar
GregP
November 13, 2008, 05:07:26 PM »
Ya know how they say there are no dumb questions. . .
How do you bleed the master?
derby
November 13, 2008, 05:25:39 PM »
Quote from: GregP on November 13, 2008, 05:07:26 PM
if there isn't a bleed valve, crack the banjo bolt. hold a paper towel over it, of course.
-- derby
'07 Suz GSX-R750
click
here
RST
November 13, 2008, 08:13:57 PM »
Just to add one little bit of info to Derby's how-to (only because I like instructions to be OBVIOUS) - after the master to the caliper with the shorter brake line first, then the one with the longer line.
I have never, ever, not once been able to bleed anything correctly, clutches or brakes. I always end up taking it to the shop.
-R.
November 14, 2008, 05:23:00 AM »
Quote from: RST on November 13, 2008, 08:13:57 PM
-R.
and yet you give advice on the topic.
erkishhorde
November 14, 2008, 06:07:29 AM »
So when you say "swapped out the brakes" did you replace the whole caliper or just swap pads? When I swapped my clutch slave it took me some 30 minutes of bleeding starting w/ an empty reservoir and no fluid in the slave. When I change pads it usually doesn't take more than 10 minutes.
GregP
November 14, 2008, 06:13:59 AM »
I swapped out the whole frontend. The SV has conventional forks and since I'm hardcore I had to have a GP Suspension fully built GSXR frontend on my bike. [moto]
This included the fancy radial mount calipers.
I have the brakes pretty well bleed at this point I just want to make sure I have my bases covered before I try to ride it to the local Starbucks!!!
Thanks for all the input and advice fellas.
RST
November 14, 2008, 08:37:53 AM »
Quote from: trouble on November 14, 2008, 05:23:00 AM
Haha - that was my disclaimer and I was chuckling when I typed it
Just because I can't do it doesn't mean I don't know HOW to do it
-R.
Gus Duc
November 14, 2008, 03:34:46 PM »
Quote from: GregP on November 14, 2008, 06:13:59 AM
Good idea Greg.................. if your brakes failed you on the way to your Starbucks we'd have to pull you out of the ocean
Let's go for a ride & test out that new front end. I bet you could keep up with me now
erkishhorde
November 14, 2008, 11:33:57 PM »
Quote from: Gus Duc on November 14, 2008, 03:34:46 PM
You guys could meet me in Ventura at about 8:30am and hit the 33.
GregP
November 15, 2008, 03:11:39 PM »
Erik,
Thanks for the invite but all my rides must be on routes that are never more than 3 miles from a Starbucks. I have an uncontrollable tendency to pose for no reason at all and Starbucks lends itself to posing. I don't drink the coffee I just pose.
I believe the 33, from FHE takes riders miles away from Starbucks so. . .
Gus,
Since you stiffed me on the bike ride this morning I'll demand that a moto ride would require I be the "fast" guy.
I have one more weekend of out of control soccer/gymnastic games and I'm back!!!
I might try to make the turkey ride next Thursday.
Gus Duc
November 15, 2008, 05:42:48 PM »
Quote from: GregP on November 15, 2008, 03:11:39 PM
Erik,
Gus,
Sorry about that Greg........
I'll make sure you're the fast guy..... especially if we see one of these
Erik,
You'll have plenty of smoke & traffic to keep you busy........ no need for friends
Have a safe trip up
