January 09, 2025, 12:22:05 AM *
News: Please Help
Author Topic: Smoothing welds (without welding) for powder coating  (Read 1600 times)
MotoCreations
« on: November 15, 2008, 09:09:46 PM »
It's been discussed on here many times -- how to smooth welds (ala frame welds) and still powdercoat but not via welding itself. (you can't powdercoat bondo!)  I've seen various metal content fillers before used with moderate success, but found one today that comes highly recommended via a powdercoating facility that does top notch work in the Seattle area.
They use a product called "Lab Metal".  Two variations are "Lab Metal" itself which is good for 350/400 degrees (just have your powdercoater back off the oven a bit) and "Hi-Temp Lab Metal" which is good for 1000deg.  link --> Alvin Products  Various methods to apply and then file/sand as required to polish out.
One cavaet though -- this isn't a replacement for actual welding -- it's purely for cosmetic purposes only.  Also talk with your local powdercoater BEFORE you do this -- make sure they are comfortable with what you are doing first.  Not all powdercoaters are the same!
supertjeduc
« Reply #1 on: November 16, 2008, 08:32:21 AM »
I think it is so harley to want to smoothing welds  Evil
cbartlett419
« Reply #2 on: November 18, 2008, 02:23:16 PM »
I heart blending, it's good for the OCD soul. but hey thanks for the heads up, I wonder what else could be done with that stuff...
TAftonomos
is without a monster :(
« Reply #3 on: November 18, 2008, 06:21:43 PM »
I'd fill in the area with some rod (TIG), and then file/sand/grind it down.  I've seen lab metal used plenty on non-stressed pieces and it works great.  I'd wonder on the frame however, if it would crack.
