having small issues, maybe you can help me
Started by acemoney, November 16, 2008, 06:34:59 PM
acemoney
I took my bike apart and i thought i would have hundreds of questions. to my suprise i only have a couple (that i can remember). they might be dumb qustions but then again i'm not the brightest individual. thanks in advance for helping if you can.
it's a 06' 620.
how do you take off the site glass off the clutch/generator covers?
do the bottom of the forks (the part that the brakes attach to) come off, if so how?
what kind of "universal puller" can i get to pull the bearing holder off the bottom off the steering tube on the bottom triple? (a link would be nice)
any cheap brands or where to get oil filter, fork seals, exhaust clamps?
Quote from: acemoney on November 16, 2008, 06:34:59 PM
it's a 06' 620.
Just tap them out gently with an appropriate driver or socket.  I would install new ones, but, then again, I am conservative
Probably, but I'm not sure on a Marzocchi fork, yes on a Showa, but it is tough.  There is a set screw held in place with red loctite (you will need heat and the threads holding the bottoms on are very fine.  No mention of this operation in the repair manual or mention of this part as separately available in the parts catalogue.
Something like this for in the appropriate size for the stem
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=10138&group_ID=1207&store=snapon-store&dir=catalog
and a hammer and punch for the tube.
These parts should not be too bad from the dealer, though you can save a few bucks on the fork seals.
More info on what you are doing would be hepful.
acemoney
Quote from: howie on November 16, 2008, 10:16:46 PM
thanks a lot for the answers
basically i'm taking all those pieces off for powder coating (i assume all that stuff would need to come of first, right?). and the other stuff i mentioned i just want to replace.
