M696 - New Oil Leak
Started by zLoki, November 17, 2008, 09:36:15 PM
zLoki
Anyone having oil leaks on a 696?
Mine seems to have developed one from the oil filter.  Here's the details;
1. No leaks before this (3000 miles)
2. Bike sat, covered in an underground garage for three and half weeks (I was out of the country)
3. Stated right up
4. Started to leak, about three sizable drops from the oil filter
5. Leak is maybe one drop while riding (that I can tell) but does not leak over night
I figure this is due to the oil filter seal contracting from sitting around for so long.
Anyone else seen this?
Mostly stock '12 796
Sold - '09 696 with 30,000 miles
CairnsDuc
Maybe grab a filter wrench and make sure it's tight, it may have become a little loose from the heating cooling cycles of normal running.
Just give it a quick tweak to be sure.
Quote from: CairnsDuc on November 18, 2008, 03:04:58 AM
But do not make it over tight.  If that doesn't work you could remove, inspect, reinstall or splurge for a new fiter.
Sleeper_I
hand tight plus 3/4 of a turn with wrench. Hopefully that should fix the dripping.
zLoki
Tried tightening the thing but also tried to not over tighten...  Looks like i'm going to have to take the thing off, change the oil in the process.
Thanks for the suggestions
[beer]
Sleeper_I
Oh, by the way did you make sure there was no rubber seal from the previous filter still stuck underneath?
