January 09, 2025, 10:52:19 AM *
Pages: [1] 2   Go Down
Author Topic: Painting the belt covers  (Read 9764 times)
herm
« on: May 11, 2008, 10:34:09 AM »
could someone who has done this already (Nakid Grin) post up a how to, specifically type of paint used, bake on time, etc...
thanks waytogo
« Reply #1 on: May 11, 2008, 11:00:37 AM »
I used BBQ paint from Lowe's called American Tradition. It's a satin black.
I started by taking off the belt covers and cleaning them with dish soap. After thoroughly rinsing them, I popped them in the oven at about 150 for 15-20 mins.
After they cooled, I used several light coats of paint allowing them to dry for about 15-20 mins between coats. Once they had 2-3 coats and they had dried for a couple hours, I put them in the oven at about 180 degrees for 30 mins to "cure" the paint.
Once they cooled, I repeated the process a couple more times and ended up with a pretty durable product. Here is the end result.
herm
« Reply #2 on: May 11, 2008, 11:03:59 AM »
thanks dude!
exactly what i was looking for. i know you posted this on TOB, but i am tired of looking there for old info Tongue
edit: DAMMIT! my oven wont go as low as 150..........suppose 200 is safe?
« Last Edit: May 11, 2008, 11:07:10 AM by herm » Logged
« Reply #3 on: May 11, 2008, 11:32:47 AM »
Should be fine. I think I've cooked the belts as high as about 240 or so...
« Reply #4 on: May 11, 2008, 12:11:56 PM »
get a red/maroon scuff pad and some Ajax.
use the scuff pad and Ajax together with some water, this will abrade and clean all in one step.
rinse well and allow to dry.
clean with some rubbing alcohol
I like to use a product from SEM called Trim Black needs no adhesion promoter and has the right sheen.
Charlief
« Reply #5 on: May 11, 2008, 12:46:49 PM »
I washed them real good with dish detergent.  Dries them well.  Then wiped down with acetone.  not letting my greasy fingers getting all over them I then sprayed light coats.  Maybe 3-4 total letting them dry between coats.  I used a paint made for automotive interior trim.  Has a nice satin finish to it.  I used it on my Corvette and got it from Ecklers.  I'm sure NAPA might have something similar.  I did not bake them.
« Last Edit: May 11, 2008, 12:53:35 PM by Charlief » Logged
Vindingo
02' 620 Dirty
« Reply #6 on: May 11, 2008, 01:20:44 PM »
Krylon makes a product called Fushion, made specifically to bond with plastics.  I havent used it FWIW...
herm
« Reply #7 on: May 11, 2008, 04:08:31 PM »
all right........anyone got a set of stock belt covers for a DS motor?  bang head
Charlief
« Reply #8 on: May 11, 2008, 05:40:15 PM »
What did you do? Shocked
« Reply #9 on: May 11, 2008, 06:09:16 PM »
yup
+1?
« Last Edit: May 11, 2008, 06:12:24 PM by red baron » Logged
herm
« Reply #10 on: May 11, 2008, 06:23:06 PM »
wellllllllllll,
while my newly painted belt covers were sitting drying before i put them in the oven, a strong gust of wind tossed them into the dirt. they didnt look so good with the dirt and scratches in the partially dry paint
so, i once they were dry, i started scraping. and then i came across this......
kind of caught my attention, so i worked on the theme a while, and this is where it stands now...
what do y'all think? pursue this look. keep going with the all black belt covers? i am going to look for some metalic flake to match the engine case, and see how that looks on the parts of the belt that are currently grey. then i am gonna see if primer and a bunch of coats will cover up the ugliness that is my painted/scraped/sanded belt covers.
and if that fails, i will be looking for another set of belt covers Roll Eyes
« Reply #11 on: May 11, 2008, 06:26:04 PM »
Looks decent, but I think for the proper look, you'd need a satin clear over the whole thing...
« Reply #12 on: May 11, 2008, 06:31:14 PM »
I like it too.
herm
« Reply #13 on: May 11, 2008, 06:35:50 PM »
i agree, it is definately rough as-is.
i guess i will spend some time staring at spray paint tomorrow.
the goal would be for the outside of the covers to blend in/disappear against the engine, while the insides are defined and highlighted in black.
not sure if the bumps over the pulleys should stand out, or fade away?
maybe i should cut em out and glue in some clear windows...?
herm
« Reply #14 on: May 12, 2008, 06:16:34 PM »
ok, almost done.
still need to put a few coats of clear on em.......
Pages: [1] 2   Go Up
