Removing Starter wire
Started by lemond, November 23, 2008, 01:08:48 PM
lemond
do I use a thinner wrench? The starter wire is bolted down by two 10mm nut but I can't seem to get my wrench into the nut closest to the starter. I remember reading somewhere that I should not have the starter bolt turn more than 1/4 of a turn or risking stripping the wires inside the starter.
2000 GSX-R 600 Track Bike
1995 Ducati Monster M900
lemond
greenmonster
Just remove #1 and wire is off.
Don`t touch #2 if not necessary, isolation washer easily cracks and starter shorts.
M900 -97
MTS 1100s  -07
clubhousemotorsports
Try to not let the wire turn as you are loosening the nut, this will reduce the chance of breaking the plastic insulator.
lemond
hmmm, it looks like the nut is seized to the bolt, the wire does turn with the nut and the bolt. Ah this sucks i hate getting seized nut/bolt...time to whip out PB blasters and hope for the best.
Quote from: lemond on November 23, 2008, 07:48:52 PM
That's what I would recommend...
krista
I run across those all the time, actually. Like said above, I will slowly but forcefully loosen the nut, watching the post turn with it a bit. All the while, I'm hoping nothing important breaks up inside the starter. I've done it a bunch of times and haven't hurt a starter yet. (fingers stay crossed)
:) Chris
