January 10, 2025, 01:08:09 AM *
Pages: [1] 2   Go Down
Author Topic: Reflashing factory ECU's to DP spec! UPDATED!!!  (Read 7556 times)
Monstermash
AKA-TomColore
Interferiscalo se potete
« on: November 24, 2008, 04:14:40 PM »
Hey all,
 Just a quick heads up to direct you all to the minor sponsor board where you will notice that I am now a sponsor of the DMF.
 I am offering a reflash for your stock ECU's to DP spec to go with your non Termi aftermarket exhaust and other mods.
 Get all the details here:  http://ducatimonsterforum.org/index.php?topic=15502.0
 I have recently found out that the reflash will completely disable the immobilizer upon the customer's request.
 Which means that you can now use aftermarket gauges on your bike without hiding the factory gauges somewhere!
« Last Edit: March 04, 2009, 07:44:42 AM by Monstermash » Logged
BK_856er
2007 M695; 2004 749s
« Reply #1 on: November 24, 2008, 05:25:30 PM »
Hey all,
Now that is cool  bow down
How does your flash affect the "pairing" of the dash and the ecu, assuming that pairing was performed?
BK
Monstermash
AKA-TomColore
« Reply #2 on: November 24, 2008, 05:29:33 PM »
BK
 Great question!
 It doesn't effect it at all. In fact it disables the immobilizer. If you use the red key it will pair it again though.
 I'm also fairly certain that once that has been done you can change out your gauges as well providing you don't use the red key in it. I'll let you all know as soon as I try it on my bike.
« Reply #3 on: November 24, 2008, 07:03:03 PM »
Well, get busy on that!
Capo
You Are What You Is
« Reply #4 on: November 25, 2008, 01:45:41 AM »
Are you able to read the maps stored on the ECU?
Capo de tuti capi
CDawg
S4RS
« Reply #5 on: November 25, 2008, 07:33:51 AM »
<bookmark>
Statler
« Reply #6 on: November 25, 2008, 11:18:19 AM »
<bookmark>
the link in the minor sponsor section is the safer bookmark.   The details and ongoing conversation about how this progresses will be there.
Exciting stuff.
CDawg
S4RS
« Reply #7 on: November 25, 2008, 11:33:33 AM »
Exciting stuff.
Thanks.  I've bookmarked that as well to keep the ECU mod thread current.
« Reply #8 on: November 25, 2008, 07:30:37 PM »
Incredible news waytogo
Monstermash
AKA-TomColore
« Reply #9 on: November 26, 2008, 10:49:40 AM »
Application list is now in my thread in the minor sponsor's section!
Monstermash
AKA-TomColore
« Reply #10 on: December 04, 2008, 01:15:37 PM »
Intro pricing no longer in effect.
« Last Edit: March 04, 2009, 07:46:10 AM by Monstermash » Logged
OverCaffeinated
« Reply #11 on: December 04, 2008, 02:55:20 PM »
How does your reflashing differ from a pciii, other than the reflashing uses your own ECM and the pciii is a piggy back system?
Monstermash
AKA-TomColore
« Reply #12 on: December 04, 2008, 02:58:28 PM »
 Well a PCIII is useless on any bike that has an O2 sensor such as the S2R1K and the S4RS.
 That is unless you have a DP ECU because it eliminates the O2 sensor.
 For more info check out Cdawg's thread at the top of the page.
Ducnial
« Reply #13 on: December 04, 2008, 05:09:55 PM »
Or to ask another way,  can you read the maps on one ECU ( read DP) and flash to a stock ECU?
Capo
You Are What You Is
« Reply #14 on: December 04, 2008, 05:22:37 PM »
I'm soon to fit a Nemisis and would like to program it with the map from the DP ECU I have at present as a baseline.
While this reflash is a MAJOR facilty (allbeit reather expesive), I want to be able to make real time adjustments on the dyno, the Nemisis allows this.
Another question, do you offer or plan to offer a immobiliser removal only? this would open up the way to replace gauges.
Capo de tuti capi
Pages: [1] 2   Go Up
