December 27, 2024, 09:16:58 AM
Please Help
Emissions removal.
Topic: Emissions removal. (Read 5138 times)
Grappa
Emissions removal.
May 11, 2008, 03:45:40 PM »
I have a 2001 M900S i.e. and the previous owner must have removed the carbon canister because I have never seen it. However, he left the tubing in place that connects each of the intake ducts, then proceeds along the frame towards back of bike, where it then would have connected to the missing canister. I bought screws to go into the holes where the tubes connect to the intake ducts, but need to put some kind of silicone
on the screws first, to prevent a vacuum leak. I have a marine/auto 100% silicone tube that says it can withstand up to 400 degrees F. Is that high enough, being that the intake duct is connected directly to the head?
Last Edit: May 14, 2008, 02:33:02 PM by Grappa
Ahh... but the servant waits, while the master baits.
Sometimes Aloha means Goodbye.
Mr Earl
2003 M800 Dark
Re: Emissions removal.
May 11, 2008, 04:03:47 PM »
Another option - that allows easy TB syncing w/o replacing the machine screws with the original tube fittings - is to use silicone caps from
www.mcmaster.com
to cap the existing fittings. They fit nice and snug and take the temperatures with no problem.
Except then the friggin' dealer mechanic loses the silicone ones and replaces them with POS plain rubber ones...
so buy several
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
Grappa
May 11, 2008, 04:09:39 PM »
Mr.Earl, that is one of the alternatives that I was interested in! Do you have a part number, looks like a huge site with many options.
MuscovyDuc
02' M750I.E. Dark - (pearl white)
May 11, 2008, 05:29:54 PM »
Just connect one of the tubes to the other throttle body. Thats what I did, I got that info off TOB a couple weeks before the fall
http://www.madog.us/
http://www.flickr.com/photos/26351347@N03/
http://autos.groups.yahoo.com/group/madog/
Grappa
May 11, 2008, 05:50:17 PM »
Yeah I could do that but I want to get rid of all the tubing possible.
Mr Earl
2003 M800 Dark
May 11, 2008, 07:01:11 PM »
Quote from: Grappa on May 11, 2008, 04:09:39 PM
If you type "silicone tube caps" into the search window on the left side of the page, you'll get a page showing lots of diameters of silicone tube caps, strangely enough. Mcmaster doesn't let you link to a specific page, or I'd provide that. The part number to fit 1/4" OD is 92805K14, but see below.
I bought 2 diameters, one of which turned out to be just right, the other a little large. Trouble is, I don't know now which diameters I bought! Sorry...
They're very flexible, so err on the small side.
They come too long, you'll have to trim with scissors for a perfect fit.
dlearl476
May 11, 2008, 09:08:40 PM »
I actually just de-cannistered mine today, in the process of installing FCRs. I took my nipples out and replaced them with stainless steel allen head screws. I'll keep the nipples in the container with my other carb adjust nipples.
Mr Earl
2003 M800 Dark
May 12, 2008, 04:51:22 AM »
Quote from: dlearl476 on May 11, 2008, 09:08:40 PM
...I took my nipples out and replaced them with stainless steel allen head screws...
Ouch!
CDawg
S4RS
May 12, 2008, 12:59:07 PM »
Quote from: Grappa on May 11, 2008, 03:45:40 PM
Are you sure?I just removed nipples, put some medium loctite on the screw and installed it. No problem so far.
uclabiker06
"The time you enjoy wasting isn't wasted"
May 14, 2008, 09:01:22 AM »
Quote
Thats b/s, dude.
2006 S2R
2009 Smart
Mr Earl
2003 M800 Dark
May 14, 2008, 03:59:58 PM »
Quote from: uclabiker06 on May 14, 2008, 09:01:22 AM
Thats b/s, dude.
Yep. They spilled brake fluid on the case, too - didn't see it until I rode it home. I'm doing all my own work from now on. Bastards.
