January 09, 2025, 12:58:40 AM *
Author Topic: Retrofit a tail chop question???  (Read 1591 times)
Ademoraes
« on: December 01, 2008, 02:34:14 PM »
Hi everyone!  Has anybody retrofitted a tail chop???I know, I know... some of you are probably thinking what is he talking about??? Is he crazy??? Well, I actually do like the Monster tail...
The reason I'm asking is because I'm planning on buying an used 05 M1000s, which has a tail, and I would like to be able to retrofit the tail.  I know... very weird... but maybe there are people out there that also like the tail and have done this.
If you guys have any comments/experience please let me know!  Also, if anyone is planning on doing a tail chop and will toss the piece left over parts, please let me know!  I'll be glad to pick it up!!!
Thanks!
1998 ZX9R
2005 M1000S
2006 749S
2008 1098
2012 M796
Omnipotent Potentate
Personal Pretext
« Reply #1 on: December 01, 2008, 07:21:59 PM »
I have a recollection of someone actually modding up a modular tail chop - even nuttier.  But if you got you hands on a chopped off tail, it would be pretty easy to put back in place.
The non welding way would be to:
Clean up both sides of the joints
Find some tubing or pipe sturdy enough for the job w/ an OD just smaller than the ID of the frame tubes - cut 2 2" sections
Drill holes 1/2" from each end of the tube and same for the frame bits.
Bolt it all up.
Welding, you'd probably end up with some bit of tube inside to act as a guide.  You'd have to clean the joint and bevel each side of the frame tubes, all the way round.  Then get to welding
Ademoraes
« Reply #2 on: December 02, 2008, 11:41:04 AM »
I had thought about the non weldding method you described.  I just wonder if anybody has done that!!!
Thanks for the input anyway! waytogo
1998 ZX9R
2005 M1000S
2006 749S
2008 1098
2012 M796
scott_araujo
« Reply #3 on: December 02, 2008, 10:00:00 PM »
http://www.ducatimonster.org/forums/accessories-mods/178739-tail-un-chop.html
Scott
Ademoraes
« Reply #4 on: December 03, 2008, 10:53:05 AM »
Hi Scott!  Thanks for your post, that's exactly what I had in mind.  I just like the fact that the monsters look slightly longer with the tail.  Plus, it's nice to keep some water off our backs when riding in the rain!
Cheers, waytogo
Anderson
1998 ZX9R
2005 M1000S
2006 749S
2008 1098
2012 M796
