S2R 800 Brake Upgrades
Started by Xiphias, May 11, 2008, 06:00:39 PM
Monstermash
Quote from: DrDesmosedici on May 12, 2008, 02:07:57 PM
Very true, that being said one nice thing about going w/ the GSXR forks is you get adjustability - which I believe the S2R 800's are lacking.
-Adam
Exactly. But the you have to worry about all the other stuff like the shim kit and installing the correct spings for the bike/rider etc.
DrDesmo
#16
Quote from: Monstermash on May 12, 2008, 02:49:41 PM
True, but the springs are an issue that's the same for any forks, any bike, any rider ... You really think those non adjustable 800 forks are well suited for everyone and any riding style?  Of course not  [moto]
-Adam
'95 916
'12 800XC
Monstermash
Quote from: DrDesmosedici on May 12, 2008, 03:05:16 PM
-Adam
Good point, but at least they are a universal fit for the S2R. I've been saying this since last year when I did Jewcati's GSXR fork swap, the GSXR forks are just too stiff for the S2R unless you respring them.
DrDesmo
Quote from: Monstermash on May 12, 2008, 03:22:37 PM
Absolutely, when I took that thing for a spin it just about knocked my fillings clear out ...
-Adam
'95 916
'12 800XC
Xiphias
Guys...thanks for ideas...I'll be busy on ebay.
Rob
Hi-ho-hi-ho....its off to the track I go.................
Wanwo
Quote from: DarkStaR on May 12, 2008, 01:28:15 PM
The lines have to be changed also.  Different lengths and ends.
So all I need is the rotors, lines and calipers? I can still use my coffins?
DarkStaR
Quote from: Wanwo on May 12, 2008, 09:51:46 PM
Your stock master will work, but the piston is smaller (-1mm?).  This may make the lever feel a little "sloppier/spongier ".
FWIW:  Others have done just that with little to no complaints though.
COWBOY
you don't need to change your coffins if you don't want to.  I ran them for 2k and they did fine.  My move to radials came later as a why not mod as opposed to looking for something I wasn't getting (I got them for a great deal).
2005 S2R -- Mods installed: DP termi full racing kit, ST4 Forks, S4R rear shock, 999 Radial Brake and Clutch MCs, 4 pot Brembo Calipers, 320mm Snowflake rotors, SBK Quick change carrier, 43T rear sproket, Tomaselli Clip Ons, Cyclecat Frame Sliders, ASV Levers, zero indicators, Supernova taillight
