2006 S2R1000, stumbling, surging, hesitation issues
Started by turnera, May 11, 2008, 08:02:42 PM
turnera
I own a 2006 S2R1000 with about 3200 miles on it. At about 3100 RPM through about 3600 RPM and at low throttle settings, the bike will stumble, even cough a little, then eventually catch and then surge. This doesn't happen at anything above about 1/3 throttle. It doesn't happen at any other RPM range. But, as an example, when I roll on small throttle while coming through a turn after a stoplight, I'll get the hesitation problem. The bike will do this at stable throttle settings sometimes just riding down city streets at low speeds. The bike has it's original ECU and a Quat-D Exbox. It started to do this at about 2000 miles even before the ExBox was installed. It is getting progressively more consistent. It has a Power Commander installed and tuned by AMS Ducati in Dallas, TX (a well known and well-respected Ducati dealer and tuner). I seem to recall that the old DMLsite (sorry to see that one go downhill so quickly) had a few mentions of this issue with possible solutions. I suspect I'm not the only one with this problem. Can any of you more experienced Monster guys help me out?
turnera
Monstermash
Quote from: red baron on May 11, 2008, 08:14:05 PM
You've got a PC on an S2R1000????
I had the same question......  [bang]
Please enlighten us.  [thumbsup]
Augustus
Termi pipes and ECU will fix the problem, but it's not cheap.
gnostic203
There was a few guys who put the DS1000 model PCIII on their S2R1000's.  Not many but a few, I believe bypassing the o2 sensor is necessary for that as well.  A few of us actually unplugged our o2 sensors and there was some great info back on the old site about a good procedure to drain the ECU of air/fuel maps.  This is really null though if you have a PCIII.  I'm not doubting but are you positive on the PCIII?  If AMS tuned your bike I'd be real curious why its surging which is usually due to a pretty lean condition.
flsurfdog
I did it.....well I had it done at DucShop here in atlanta if yall remember from the old board.   Long and short is yes you use the PCIII for the DS1000 (it plugs straight in as it will with several monsters).  Then you disconnect the O2 sensor and finally plug the vacuum hoses.  (I think this means you're unplugging the stepper motor or something but i don't know exactly, but really all you do is plug those hoses) and then you tune it.
This kept the ECU from adjusting the map allowing the PCIII to do it's job.  It runs perfectly but the trade off is that it idles like crap when cold. Mark at the Ducshop ended up putting a fast idle switch on my handle bar, which i used to get the bike nice and warmed up.
I'd say the bike ran like ass until it got around 140-150 F, then ok up to 180-190, then amazing above that.  So if you ride short rides to work every day and it's chilly then it probably isn't that great....but if you got a long commute or are only riding on weekends it's a pretty good option.
I guess this post really belongs in the accessories and mods stickey, but i'm just answering the question
06 s2r1000, Apex Clip-ons, Lowered headlight and gauges, HID high/low, Wasen Design front signals, reflectors removed, Mag Performance clutch cover, Rizoma star pressure plate, open airbox, Spark midpipe, Leo Ti slip-on, tail chop and frame plug blinkers
Monstermash
Quote from: flsurfdog on May 13, 2008, 04:47:32 AM
Which vacuum hoses do you plug? And where are they disconnected from in the process that requires them to be plugged?
gnostic203
Good info flsurfdog, but yeah which vacuum hoses are you referring to?
flsurfdog
Quote from: gnostic203 on May 14, 2008, 08:10:35 AM
Hey guys, sorry i haven't been around to answer.... let me check to make sure when i get off work today.  It's been a while since i've been under the tank.
gnostic203
I thought there was some sticky too about the various options on these bikes (PCIII, RapidBike, etc).  Can't seem to find it.
David Lowenstein
Here you go:
http://www.ducatimonster.org/forums/showthread.php?t=163735
Quote from: gnostic203 on May 16, 2008, 09:18:08 AM
Dave in DC: 67 Jaguar E-Type OTS S1/71 Ford F-100 Styleside/79 Triumph T140E Bonneville/15 BMW R1200GS/13 KTM 300 XC-W/04 Yamaha TT-R250/04 & 05 Honda CRF 250X/Keeping parts guys in business nationwide
CDawg
turnera,
Do you have a closed or open airbox?  If you have the OEM airbox and prefer the bike to run smooth-ish (but factory lean) then maximize HP/torque then consider reversing almost everything.  ExBox works well with stock ECU and stock airbox if you keep the stock O2 sensor.
If you prefer to maximize HP/torque, then check with the previous owner to see if the PCIII was custom mapped andif it was how long between unplugging the O2 sensor and the custom mapping.  The stock ECU is a learning ECU (minor-ly adjusts to your riding style) according to Rockwell Cycles.  It take the ECU ~100 miles to give up and stabilize once the O2 sensor is removes before it fully switches to open-mode.
flsurfdog
Quote from: flsurfdog on May 16, 2008, 04:42:22 AM
OK so unless i'm missing something it's the two vacuum hoses that run from the airbox and into the base of the throttle bodies.   They're fairly small but shouldn't be hard to find since there aren't many other holes in the airbox and they suck in a good amount of air.  if you plug it the bike will stumble and probably die....hence the need for the fast idle switch.
hope that helps.....i'm gonna try and see if i can figure out how to do it myself soon.  (keep in mind this is second hand info from what my understanding of what i was told)
