bike starts and then not
Started by muskrat, December 07, 2008, 04:02:53 PM
muskrat
ok so Elizabeth and I went riding today, she did exceptionally well, and after filling up our bikes I turned the key and NADA!  I turned it back and then did it again.....vuala it crancked.  seems to be a repetitive thing.  the guages sweeped across and all lights functional and no she was not in gear with kickstand down.
any ideas or suggestions?
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
bryant8
2008 848
26.2 done 12/5/2010
70.3 by 10/12/2011
140.6 by 12/31/2012
muskrat
Quote from: bryant8 on December 07, 2008, 04:05:18 PM
Kill switch perhaps?
nope, that's good too.  thinking ignition maybe????
2015 MTS 1200
09 Electra Glide
Duc L'Smart
Quote from: muskrat on December 07, 2008, 04:10:17 PM
Are you in neutral, clutch in?
If so, sounds more like a loose connection somewhere...
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
bryant8
2008 848
26.2 done 12/5/2010
70.3 by 10/12/2011
140.6 by 12/31/2012
muskrat
2015 MTS 1200
09 Electra Glide
ducnut
I have had this happen once where although the bike was in neutral (based on rolling freely)the neutral light wan't on and bike wouldn't start.  I eventually just nudged shifter a hair, light turned green and bike started.  Agree with other rec regarding ground.
muskrat
2015 MTS 1200
09 Electra Glide
muskrat
Quote from: muskrat on December 07, 2008, 07:15:40 PM
what ground wire?  so many wires there.
BUMP.
can someone help with the ground wire issue????
Thanks
2015 MTS 1200
09 Electra Glide
TresGatos
Had that once after washing, let it sit for 20 and never happened again.  That's all I know.
'65 Honda CM91 - '98 Suzuki DR650 - '08 695+mods - '08 Hypermotard 1100S
muskrat
Quote from: dosgatos on December 08, 2008, 09:40:53 AM
I'm always careful to never spray water there but it hasn't been soaked or washed in over three weeks.....
2015 MTS 1200
09 Electra Glide
bryant8
Find the negative terminal on the battery and follow the cable that attaches to the frame. It it's loose or corroded that may part of the issue. Put a battery tender on the bike and let it trickle charge.
2008 848
26.2 done 12/5/2010
70.3 by 10/12/2011
140.6 by 12/31/2012
♣ McKraut ♣
IIRC the ground should be back near your rear brake reservoir??  my memory sucks though so i could be off.
-  Dallas, TX
greenohawk69
Quote from: bryant8 on December 08, 2008, 09:59:49 AM
Had this problem with my M900 ('97) this summer.  Ground is on the Left side (sitting on) and under the battery tray.  Use a screwdriver on it.
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
